Old 02-13-2013, 07:30 AM   #1
1966 22' Safari
Matagorda , Texas
Propane lines
I have a 66 safari.when removing the bottom skin,I found the propane line from the front to the middle of the coach was on the outside of the skin.is this correct,or should the lines be between the frame and the skin.
Greg65 is offline   Reply With Quote
Old 02-13-2013, 07:54 AM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Those line should be outside the structure. All joints too....that is to the light, stove and heaters. This avoids a gas build up bomb if there is a leak.
Old 02-13-2013, 07:56 AM   #3
Kevin245's Avatar
Hi Greg,
The lines are normally routed under the coach. While this seems somewhat contrary, it is a safety issue. In the event of a propane leak vapors could build up in the enclosed space if the line was enclosed.
Take care,
Kevin
Eleanor Roosevelt
Old 02-13-2013, 02:06 PM   #4
damonbeals's Avatar
1998 31' Excella 1000
1979 23' Safari
Mooresville , Indiana
Yes even the latest models of Airstreams have the propane lines ran outside of the belly pan. Make sure you leak test, you may find that the shutoff valves are now leaking due to age. Get a bottle of dish soap and coat every fitting and connector and looks for leaks.
Damon
#4827
damonbeals is offline   Reply With Quote
Old 03-01-2013, 12:20 AM   #5
alumascoupe's Avatar
1966 26' Overlander
Frozen , Tundra
I also own a 66 and thought the same thing you did, why are these lines under here ? So yes, that is normal. I still think its odd to put pipes full of flammable gas exposed on the underside, where rocks and other off road debris or trail ruts could destroy them. I guess theres nowhere else to hide them out of sight without fumes building to explosive levels.
alumascoupe is offline   Reply With Quote
Old 03-01-2013, 08:17 AM   #6
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
You'll find that some folks have actually put plastic/rubber hosing over their copper lines as an added source of protection from rocks, etc....since they are on the outside and could conceivably get some unwanted damage. I plan on doing this myself in the next few weeks.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
