Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 06-21-2019, 12:24 PM   #1
Rltports's Avatar
2015 25' Flying Cloud
Bettendorf , Iowa
Propane line brackets issue
We recently purchased a 2015 25ft flying cloud. So far so good but one of the rear tires had a slow leak from a screw in the middle of the tread. After repairing the tire I noticed two brackets had come loose that hold the propane line to the underbelly of the camper. One of the brackets was missing a screw which appears to have found its way into the tire directly behind it. The other bracket still has the screw attached. My question is.. what are these brackets attached to? The screws appear to be metal screws not wood screws. Are these screws attached to a frame structure on the other side of the belly pan or do they just attach to the belly pan which doesn’t seem very stable to me. I’m just not sure the best method to replace these brackets.
I’m attaching a photo to show the length of the screw and the size of what was the original hole. Click image for larger version
Rltports is offline   Reply With Quote
Old 06-21-2019, 12:44 PM   #2
2007 22' International CCD
Those should be sheet metal screws.
That said, I’d replace with pop rivets to avoid the screw shedding problem.
One of the corollaries to Murphy’s Law says that a dropped object will always land where it will do the most damage, and a long screw will find its way into a tire.
A pop rivet is less likely to cause a problem because it is much smaller and blunt.
Thanks for giving me yet another thing to crawl under and check for...🤪
Old 06-21-2019, 01:08 PM   #3
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
If you want to fix it once, use a rivnut and screw with a lock washer.
pcskier is offline   Reply With Quote
Old 06-23-2019, 01:08 PM   #4
Rltports's Avatar
Bettendorf , Iowa
Thank you PCSKIER. I just learned something, had never heard of a rivnut.
Connecting home hot water line to '67 Overlander hot water line w/PEX~Sharkbite Billyjchase Plumbing - Systems & Fixtures 4 06-29-2020 09:00 PM
Chain brackets and propane cover? retiree Hitches, Couplers & Balls 7 04-19-2018 07:16 PM
Weight distribution brackets and the Propane gas line along the Otterbrawten Towing, Tow Vehicles & Hitches 16 05-11-2016 11:37 AM
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
Propane and Electrical Line Protection Tamara Electrical - Systems, Generators, Batteries & Solar 7 06-27-2002 09:42 PM
