Old 10-29-2006, 11:27 PM   #1
kamo's Avatar
burbank , California
propane line 1/4" or more?
Hello,
Replacing the gas lines on my '62 Bambi. I have a small fridge, original stove, small water heater and original furnace.
I'm thinking about these two options:
- use a 5/16" main line and 1/4" lines to appliances or
- use 1/4" piping all around
Can a 1/4" piping provide enough gas?
Kamo
kamo is offline   Reply With Quote
Old 10-30-2006, 03:29 AM   #2
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Arrow LPG piping replacement.
Originally Posted by kamo
Hello,
Kamo
Hi Kamo; Since you replacing exsisting equipment, the size of your end fittings and valves dictates what you should use. 1/4" for feed line is kind of small, especially if the demand will come for use of them all at once. I would stay with original size and reuse the ends. Thanks, "boatdoc"
boatdoc is offline   Reply With Quote
Old 10-30-2006, 06:55 AM   #3
Images: 59
Kamo,
I just redid my '59. I used 1/2" black iron (threaded steel) for the main header (equivalent to 5/8 copper), then 1/2" copper for branches, with 3/8" lines to each individual appliance. I wouldn't use 1/4" for anything other than a lamp fixture.
Old 10-30-2006, 10:59 AM   #4
kamo's Avatar
Thanks!
LP supply line uwe LP Gas, Piping, Tanks & Regulators 9 06-17-2009 02:49 PM
Propane injection Rik Mechanics Corner - Engines, Transmission & More... 13 09-23-2003 10:34 AM
Oven gas line broken lbrodsky LP Gas, Piping, Tanks & Regulators 4 07-23-2002 03:52 AM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 03:54 AM
Propane and Electrical Line Protection Tamara Electrical - Systems, Generators, Batteries & Solar 7 06-27-2002 09:42 PM
