Old 04-07-2007, 08:33 PM   #1
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Propane Lighting
As we bring our 71 back into shape we are trying to maintain everything as original as possible. I presume that the propane lights Airstream offered were an option. They have been listed on Ebay but seem very pricy - however, we found a source for new ones that look much like the originals.
With that in mind the question/your opinion asked is - would you install a propane light in a 71 Overlander as a vintage accessory since it was available on that model. Also, if you have one - does it cause soot build up on the ceiling?
Thanks for your thoughts....
Old 04-08-2007, 12:43 AM   #2
1960 24' Tradewind
santa barbara , California
Hey there Gary ,
I would put it in your airstream .It gives that authentic appeal your after.
And in a worst case scenario ,no power ,you would have light if needed .I
have the original lamp in my 60 with coleman mantles from the 60s new in
the wax paper with one in the lamp at the ready ! Of the ones I have used in trailers (not yet on my trdwnd) I don't recall really any trouble with soot .
Id not mount it any higher than it would have been originally if your coach had it .
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 04-08-2007, 08:34 AM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Does anyone know the carbon monoxide situation with these lamps? Is there a requirement to keep a top vent open, or at least cracked? I've recovered one from a '71 Overlander (the one in Baker) and have considered it a good idea for really cold days or when the battery gets low. It also gives you a feeling of the "old days" when a tent was all you had.
Zep
Old 04-08-2007, 08:43 AM   #4
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Zep
Flame = need for venting.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 04-08-2007, 09:08 AM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Zep ~ The production of CO is always an issue. If it does not produce CO it will still deplete the Oxygen in the trailer. The bottom line is: crack a window and have a working CO detector.
Richard
Old 04-08-2007, 09:26 AM   #6
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I highly recommend putting in a gas lamp.
When I burn mine, which is almost everynight as I'm straightening up before bed, I crack the galley window about an inch and open the top rectangular vent about a half inch. On cold morningas, I light it when I light the burner for coffee just to take the edge off. One very cold night, I left it one all night just for the heat. As long as the lamp has a shield above it, you shouldn't have an issue with soot.
Here's a couple of pictures of mine showing location. You'll want to put it in a place where you won't be bumping it with your head or any flammable item as the globe gets very hot. Don't ask me how I know.
FF
ID:	35350   Click image for larger version
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 04-08-2007, 09:33 AM   #7
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
I keep thinking I want to add a propane lamp to my rig and have gotten so far as bidding now and then. One major problem for me has been figuring out where to mount it so the lighting would have the greatest effect.
Rodney
and the
My Blog
Old 04-08-2007, 10:13 AM   #8
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Thanks for your thoughts. I was thinking about mounting it about where the bottom of the extinguisher is in the photo. Thermostat is for the original air conditioned so not an issue. It's still there because it was - so it will stay. Pardon my manners by the way - here's the link to the new Humphrey Paulin lights. Not as reto/kewl as the one Flyfshr has but seems to me to be better than fighting for one on Ebay......
propaneproducts.com: Gas Lights
Old 04-08-2007, 11:04 AM   #9
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Originally Posted by Ganglin
I presume that the propane lights Airstream offered were an option ... if you have one - does it cause soot build up on the ceiling?
Hi Gary:
Most, if not all, propane lights have an adjustment for the air-to-fuel ratio, so if a light you install is creating some soot, you can and should adjust it. Soot would indicate too much fuel and not enough air, so increase the size of the air intake opening. The adjustment mechansim is typically found at the base of the stem near the wall mounting plate. Some are threaded, others just slide.
Most propane lights also have a shield or deflector above the globe top vent opening to dispurse the hot air and discourage staining of the ceiling or wall. Some people have installed a metal plate or heat shield on the ceiling itself, especially if the light is mounted high, close to the ceiling.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 04-08-2007, 11:14 AM   #10
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Gary,
That Paulin/Humphrey is the light that was orginally used in the 70's vintage units. I plan on adding one to mine when it goes back together for all the reasons Fred listed.
Aaron
WBCCI #XXXX AIR #2495
Old 04-08-2007, 11:21 AM   #11
Excella CM's Avatar
1978 31' Excella 500
Venice , California
If it were me I would move the extinguisher and put the light there. You want it as high as possible but with adequate clearance (@10") to the ceiling. They don't make soot, but they use oxygen and they run hot like a coleman lantern. You've got LP for the refrigerator right there too and just need to tap into the supply line. The old copper is no doubt work hardened so use a torch to anneal it before trying to flare it for the fittings. I particularly like getting both heat and light from the same device. The fragile mantle also makes a good vibration monitor for wheel balance. If it breaks every time you move the trailer it make indicate excess vibration. I wouldn't have rig, vintager or new, without one.
Name:	Excella's gasight.JPG
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 04-08-2007, 11:44 AM   #12
1975 31' Sovereign
1977 23' Safari
Would it were so that any of my Airstreams were so sealed that I should worry about CO production! I was only worrying about the possibility of a hot ceiling, really. The open upper vent just encourages the leaks I have around every durn window and the door--good flow, like for the fridge.
But, on a scale of 1-10, where does a propane lantern sit when it comes to CO? The new catalytic heaters seem to boast of little to no CO production, so they are down at 1. At least my Mr Heater hasn't killed me yet. I continue to think that the slight headache in the morning is due to MR. Two Buck Chuck.
Yes, put the lamp where the fire extinguisher is. That's where it was in the Overlander I took mine out of.
Zep
Old 04-08-2007, 10:07 PM   #13
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, would it start a war if I suggested converting the gas lamp to 12 volt incandesent lamp? No CO, no gas lines, a lot less heat, and still retro looks.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-08-2007, 10:10 PM   #14
2002 25' Safari
Dewey , Arizona
Images: 62
I think the reason the gas lamp is wanted is because it requires no battery power and it also puts off a little heat.
Richard
Propane injection Rik Mechanics Corner - Engines, Transmission & More... 13 09-23-2003 10:34 AM
Disposable Propane Bottle Safety JaceBeck Our Community 6 07-02-2002 01:15 PM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 03:54 AM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
Propane valve leak Dbraw LP Gas, Piping, Tanks & Regulators 3 06-14-2002 06:12 PM
