Old 04-09-2007, 09:46 PM   #15
r&kweber's Avatar
1959 22' Flying Cloud
Seattle , Washington
Ours is in the same location as flyshr's and looks great. It provides some heat and makes a great quality of light. I wouldn't ever take it out. It is near the ceiling so it gets warm, but not hot.
I do have a problem with breaking mantles though. I bought some mantles for the light from gas-lights.com and they break every time I move the trailer -- even moving it around the block slowly. What gives? The Coleman lantern's mantles that is stored in a case on the floor of the trailer seems to be bulletproof! They never break.
Is there a solution to this? I tried the Coleman mantles, but they don't burn right. Is there a more durable brand?
r&kweber is offline   Reply With Quote
Old 04-09-2007, 09:58 PM   #16
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
Lehmans.com
This place sells the tie on mantles that are as their catalogue says "are jolt-resistant, for use in RV's, campers and boats. They also sell high alt jets etc. for Paulin gas lights. I have purchased Alladin light parts from them in the past. and were treated well, would buy there again.
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 04-09-2007, 10:02 PM   #17
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I've only used the newer Coleman mantles and have had only one ever turn to dust in 6 years and I've been down some 5 mph rough roads. Try adjusting your set screw and make sure your mantles burn almost white.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 04-09-2007, 10:50 PM   #18
r&kweber's Avatar
There's a set screw? I'm sure I have the same light as yours, a Veritas? Any description would help. I'm not opposed to trying the Lehmans mantles, but I already have a handful of the Coleman type for the outside lantern.
Old 04-09-2007, 10:56 PM   #19
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
It's not really the typical set screw per se. Its the adjustment for the air-to-fuel ratio in the brass just above the aluminum base that holds the globe. I can't remember where mine is set and my trailer is in storage or I'd go look. Another thing to consider is how is/are your axle(s) and springs? I had a new axle made and had my original springs tested. As mentioned previously, a worn out axle will cause the whole trailer to ride rough.
FF
Old 04-09-2007, 11:01 PM   #20
r&kweber's Avatar
aah, sorry. I misunderstood. We were never able to find that perfect point with the Coleman mantles, so I switched to the larger ones meant for the lower pressure? They burn great, but one mantle per weekend seems wasteful. Sorry to hijack this thread.
Propane injection Rik Mechanics Corner - Engines, Transmission & More... 13 09-23-2003 10:34 AM
Disposable Propane Bottle Safety JaceBeck Our Community 6 07-02-2002 01:15 PM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 03:54 AM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
Propane valve leak Dbraw LP Gas, Piping, Tanks & Regulators 3 06-14-2002 06:12 PM
