Old 07-23-2016, 03:16 PM   #1
StreaminGeo's Avatar
2004 25' Safari
Hanford , California
Propane leaking -- not leaking
Whilst inspecting the twin propane tanks on our 2004 Safari I detected an oder of propane. I determined that it was leaking from the spot indicated by the arrow in the photo. I could feel the gas leaking out. So I disconnected that tank and switched to the other. I also called AS and had them order two extra hoses. Then, a week or so later, I noticed the same kind of leak on the remaining hose. But when I went to check it again the next day (and daily for about a week since) the leak stopped! We haven't run out of propane at all. Is this intermittent leaking something normal? Or should I replace both hoses when I get the new ones? Right now there's no smell of propane, no feel of it leading out of the spot, and no shortage of gas for cooking, heating water, etc.
What do you think?
Thanks!
Name:	Propane Tank Final.jpg
StreaminGeo is offline   Reply With Quote
Old 07-23-2016, 03:40 PM   #2
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
We've had the same problem. Go ahead and replace.
Those are, by the way, generic items. Available on Amazon and elsewhere.
Lynn
WBCCI 21043
Old 07-23-2016, 05:37 PM   #3
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
If those are the original hoses then replace. I'm thinking of replacing our hoses and regulator as they are 9 years old. The hoses are not very flexible. Did you recently get the tanks filled?
Kelvin
Old 07-24-2016, 08:54 PM   #4
2004 25' Safari
Okay, I'll replace both hoses as soon as they come in, which should be within the week.
Old 07-24-2016, 10:48 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
For future reference. Your local propane supplier can make new hoses.
Old 07-25-2016, 02:05 PM   #6
Albuquerque , New Mexico
I'd suggest using soapy water to detect a leak. It's much more sensitive method than using your nose or feeling for escaping gas.
Airhead59 is offline   Reply With Quote
Old 07-25-2016, 02:17 PM   #7
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
When refilling tanks I have noticed that sometimes I don't get the connector threaded on just right and it leaks a bit when I turn on the gas ... usually audibly AND smells, of course. If that happens, turn off the tank, unscrew the connector and re-seat it...then turn the tank back on. Also check with soapy water. If you cannot get the leak stopped, the hoses should be replaced. Our rig is a 2006 and we have replaced our propane tank hoses once so far.
TB & Greg and Abbey Schnauzer
#3954
Old 07-25-2016, 03:11 PM   #8
2014 16' Sport
Walnut Creek , California
Propane leaking
I had the same leak on my new Bambi on both tanks. So the problem was not from old hose. I tried to tighten by hand with no luck, so out came the old channel locks and I got about a 1/8 turn. No more leaking. Even a little scoring of the hard plastic is better then buying new hose from Airstream.
Elbo is offline   Reply With Quote
Old 07-26-2016, 12:38 PM   #9
JConsroe's Avatar
2005 28' International CCD
Salem , Virginia
When ours began to leak, I replaced them with hoses that have a stainless steel jacket over the rubber. We store our AS outside and mice like to chew rubber. The SS jacket protects the line from the varmint.
JConsroe is offline   Reply With Quote
Propane Gas Detector Went off Last Week-Turns Out NOT the Propane breezyway Electrical - Systems, Generators, Batteries & Solar 4 08-16-2014 09:56 AM
Newbie Advice on Propane and Propane Accessories Socal1 LP Gas, Piping, Tanks & Regulators 1 07-15-2013 01:36 PM
Leaking propane? Mike Leary LP Gas, Piping, Tanks & Regulators 8 10-24-2012 09:22 AM
Leaking propane bleeder screw classic67 LP Gas, Piping, Tanks & Regulators 13 09-06-2006 02:08 PM
Freezer works on propane - but not fridge adamstarr Refrigerators 2 08-14-2006 01:53 AM
