Old 01-10-2019, 11:38 PM   #1
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Propane leaking!
Today my propane tank started leaking. Well, not exactly. Looks like the overflow port on the back of the valve started leaking propane. I shut down the tank by closing the valve, but apparently, that did not stop it from expelling gas.
So what was happening? It appears that when it was filled by the campground, they overfilled the tank. Today was the warmest day we've had in three weeks. I'm guessing the warm weather expanded the gas. Gas was coming out of the rear valve. It is the port with the hex head in the tube. Am I correct in this assumption? Has this happen to anyone else?
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
***Support Airstream Forum***
turk123 is offline   Reply With Quote
Old 01-11-2019, 02:23 PM   #2
Zil
Curtis Wright
Eyren Haven , South Jersey
That is the best guess from here. There should be a over-pressure release that will open if high pressure. Maybe in different locations by brand. You could open the over-flow bleed valve, used when filling, and drain off propane. Carefully!
Zil is offline   Reply With Quote
Old 01-11-2019, 03:25 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you are not comfortable bleeding the tank off at least light the stove and burn some off. Another approach would be to weigh the tank and check it against the gross weight stamped on the tank.
Don't leave it till spring.
2004 Excursion 4x4
Propane tank leaking out of Allen screw on valve oldtrucksrul LP Gas, Piping, Tanks & Regulators 5 03-15-2017 08:41 PM
Propane pigtail hose connector is leaking m.hony LP Gas, Piping, Tanks & Regulators 43 10-13-2016 05:10 PM
Propane leaking -- not leaking StreaminGeo LP Gas, Piping, Tanks & Regulators 8 07-26-2016 12:38 PM
Leaking propane? Mike Leary LP Gas, Piping, Tanks & Regulators 8 10-24-2012 09:22 AM
Leaking propane bleeder screw classic67 LP Gas, Piping, Tanks & Regulators 13 09-06-2006 02:08 PM
