Old 05-17-2019, 06:38 PM   #1
Beaufort , South Carolina
Propane Hose to Butane grill adapter.
The 2019 Sport comes with a hose to run propane from the trailer to a grill. However, the hose end that is supposed to connect to the grill does not fit the port where the butane can attaches. There must be some sort of adapter required. Any recs????
Thank you!
talbird is offline   Reply With Quote
Old 05-17-2019, 07:49 PM   #2
Baby Zeppelin's Avatar
2018 28' Flying Cloud
Clayton , Georgia
Grills that use the small green propane cylinders have a pressure regulator. Your Airstream propane system also has a pressure regulator. You'll have to remove the regulator from your grill and use suitable adapters for the Airstream low pressure system.
Here is an example for the Weber Q grills: https://www.amazon.com/M-B-Sturgis-I...40194830&psc=1
Or you can make your own, U-tube has some videos that can guide you.
Erik & Carol
Clayton, Georgia
AS: 2018 Flying Cloud 28 "Baby Zeppelin"
TV: 2017 Ford F250 Lariat w/ Blue Ox Sway Pro
AIRForums #126944 WBCCI #1297
Baby Zeppelin is offline   Reply With Quote
A hose is a hose is a hose Vitaver Plumbing - Systems & Fixtures 38 09-23-2020 10:41 AM
Veritas lamp butane/propane 30 cms wg Support Admin Airstream Classifieds 0 09-23-2013 04:55 PM
horizontal butane tanks 123pat.buie LP Gas, Piping, Tanks & Regulators 3 10-03-2011 10:31 PM
butane vs propane? lwebb LP Gas, Piping, Tanks & Regulators 16 08-11-2008 07:33 PM
Propane + Butane Danetree LP Gas, Piping, Tanks & Regulators 2 11-22-2005 08:34 PM
