The 2019 Sport comes with a hose to run propane from the trailer to a grill. However, the hose end that is supposed to connect to the grill does not fit the port where the butane can attaches. There must be some sort of adapter required. Any recs????
Grills that use the small green propane cylinders have a pressure regulator. Your Airstream propane system also has a pressure regulator. You'll have to remove the regulator from your grill and use suitable adapters for the Airstream low pressure system.
