Old 02-15-2009, 04:23 PM   #1
2010 27' FB Classic
N/A , Texas
Propane Hose Replacements
What site do you guys go to for rubber replacement hoses with fittings for the LP tank to the regulator? I'll be replacing my regulator and should replace the hoses at the same time.
Old 02-15-2009, 04:35 PM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Camping world or just about any RV supply place.
Michelle TAC MT-0
Sarah, Snowball
Old 02-15-2009, 04:48 PM   #3
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Even from a dealer the hoses aren't terribyly expensive...
And I replaced Regulator without changing hoses, and had to then go to a shop to find the propane leak that my handiwork had created.. FLexing and removing hoses (that were elderly..) created a crack and led to the small leak I could smell but not find..
Condoluminum
Condoluminum is offline   Reply With Quote
Old 02-16-2009, 08:26 AM   #4
Dan@LED4RV's Avatar
Denton , North Carolina
replacement
Yes you will want to replace them also. Mostly so you won't have to get a wrench out every time you want to fill them up.
Click here to see the hose flaired end.
Click here to see the hose straight end.
Click here to see the Regulator.
Dan
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 02-16-2009, 08:32 AM   #5
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
Is there a source for the old style hard lines? My 67 has one hard(metal) and it is much nicer than the rubber line. The sun does not rot it like the rubber line. Thanks, John
Diesel1 is offline   Reply With Quote
Old 02-16-2009, 08:57 AM   #6
rogerdodger's Avatar
Fresno/Clovis , California
I bought my regulator after research on the airstream website, they recommended this one, I bought it at the below website, and hoses.
Automatic Changeover LP Regulator
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 02-16-2009, 03:18 PM   #7
Keymar , Maryland
It would require plumbing tools or a plumber to make those these days.
Michelle TAC MT-0
Sarah, Snowball
Old 02-16-2009, 05:03 PM   #8
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Diesel1,
If you want to do hard copper lines from the tanks to the regulator you can get all the soft copper coil pipe, brass flare fittings, and flaring tools that you will need at Home Depot, Lowes, or the like. Some people shy away from propane line repairs, but it is relatively simple and if you take your time they are perfectly safe. If you tackle them yourself just remember to leak test any new connections with windex or soapy dishsoap water. Any leaks will appear as growing bubles.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 02-16-2009, 10:39 PM   #9
2010 27' FB Classic
N/A , Texas
Thanks for the links for the flexable LP rubber hoses. Once I get those parts ordered and installed, I'll be just about ready to hit the road again.
Old 02-17-2009, 08:41 AM   #10
Diesel1's Avatar
1967 24' Tradewind
Originally Posted by DEITZ645 View Post
Diesel1,
Thanks, I have the flaring tools but the one original line I have is not flared. It has a neat little machined fitting that looks to be silver soldered to the line, then the acuall threaded nut rotates behind the soldered fitting.The end that goes into the regulter does not turn on the line, it is soldered fast. It is a very tidy setup. Adios, John
Old 02-17-2009, 09:11 AM   #11
Hard copper lines, connecting the LPR regulator to the bottles, was outlawed many years ago.
Primary reason was fatigue cracking.
The rubber hoses should be replaced when there are "ANY" signs of cracks in the rubber.
Is furnace duct hose the same as household dryer duct hose? Bearstream1 Furnaces, Heaters, Fireplaces & Air Conditioning 4 01-12-2009 10:21 PM
'64-65 toilet replacements... 59er Sinks, Showers & Toilets 22 09-04-2007 11:08 AM
Oil in the propane line and a connecting hose dbensen LP Gas, Piping, Tanks & Regulators 2 10-20-2005 07:50 AM
ST Tire Replacements LTD93 Tires 4 09-28-2005 04:15 PM
Accuslide replacements TBYRNE Airstream Motorhome Forums 3 07-12-2002 06:21 AM
