Old 03-10-2010, 08:04 AM   #1
hshovic's Avatar
2007 25' Safari FB SE
Bozeman , Montana
Images: 20
Propane goop and keeping fridge going during travel
I had to replace my regulator because of oily goop in it (25,000 miles on the trailer). Symptoms were low pressure at times. The RV repair place thought it was from overfilling a tank, getting liquid propane in the line, where it evaporates and leaves oily residue from the various additives. Another opinion by the gas company is that liquid propane gets sloshed around during travel if the gas valves are open, doing the same thing. Actually,they told me since RV's don't generally have sediment traps in their gas appliances, it could possibly puddle in the appliance making a fire hazard.
Both seem likely, so it is a reason to turn off the gas during travel at the tank. And another reason to make sure the propane fillers always open the bleed screw to make sure no overfill occurs.
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
hshovic is offline   Reply With Quote
Old 03-10-2010, 09:40 AM   #2
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Oily goop? It does not require liquid sloshing, post regulator lines running at atmospheric pressure can get black wax oiled from just one bad batch of propane. Your Northern area true propane content is probably a minimum of 90% with maximums of 5% butane and 5% propylene - there should be no other additives, thats a touch of spin control from the suppliers -- but liquid propane is an excellent solvent and improper handling or equipment in the supply chain or gives a nasty product. If you replaced the regulators you could still be carrying a problem in your tanks...
Old 03-10-2010, 09:47 AM   #3
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I have found a lot of oily goop in the bottom of tanks when replacing valves. I have alway assumed that this from the additive that is used to give propane its onion smell.
I have also noticed as you get to the bottom of the tank I will get odor from pilot lights etc. It disapears as soon as the tank changes over.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 03-10-2010, 10:07 AM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
There was an RV article that I read Monday that mentioned this problem to a limited extent. Their recommendation to help prevent line build up was to always shut off the tanks and let the appliances burn off all the gas in the lines. Something to think about anyway...
Old 03-10-2010, 10:54 AM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
That's contaminants, not additives. Otherwise, they're probably right. Since the contaminants don't vaporize, they accumulate over time in the tank.
The vapor withdrawal port is located in a place where it is nearly impossible to get any significant amount of liquid propane into it by splashing from a properly filled tank.
They're called drip legs, not sediment traps. Since RVs have a piping system designed so that the piping extends vertically from under the trailer to each appliance, any contaminants are trapped in the pipe below the trailer just as effectively as they would be in a drip leg.
They should not only use the bleed screw, they should weigh the tank.
Old 03-10-2010, 10:58 AM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
Methyl mercaptan, the odorant in propane, does not itself form an oily goop, though it does have a somewhat lower vapor pressure than propane leading it to accumulate and have a higher concentration towards the end of the tank.
Old 03-10-2010, 11:00 AM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
I think this is nothing but FUD. If it's really a problem it could be solved easily enough by forming a loop in the pigtail from the tanks to the regulator.
Old 03-10-2010, 09:35 PM   #8
Maniacal Engineer
barts's Avatar
Menlo Park , California
From what I've been told by fire effects folks who go through _lots_ of propane, some suppliers have significant oil vapors in their propane.... not much of an issue for a 2" dump valve for fireballs, but for a small orifice at .5 psi this could be problematic. It does help reduce tank rusting w/ steel tanks, I guess.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Fridge heating up on propane Jenturner Refrigerators 12 11-09-2008 09:29 PM
how much propane to run a fridge? Rollerboy Refrigerators 4 10-23-2007 11:50 AM
keeping fridge cold bfred Refrigerators 1 07-30-2007 10:09 PM
Using Goop? & gaskets stellablu Our Community 4 09-07-2003 09:32 AM
Propane fridge installation yaakman Refrigerators 5 09-12-2002 07:34 PM
