| Propane gauge install
The safari se I just purchased does not have a propane monitor so I purchased one of those in-line gages. However, there is not enough room to install inside the tank cover. I purchased a 5' 'propane hose assembly' off the shelf to help the situation but the connections are all wrong. I cannot seem to find anything that would help -like an elbow or a hose extension with the correct fittings. I cannot turn the tanks around because I would then have to cut the hoses already there and I am trying to avoid that. Anyone know where I can get a connector to do the job easily???
