Old 07-14-2006, 01:22 PM   #29
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Found this temp vs pressure table:
0F 25.5 psi
40F 65 psi
70F 110 psi
110F 204 psi
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 07-14-2006, 01:42 PM   #30
Paul Mayeux's Avatar
1954 22' Flying Cloud
1954 25' Cruiser
2005 25' International CCD
Paradise , Texas
dtbw on this forum has a cool setup. He has a led light connected to a attachment that goes on the regulator. He keeps both valves opened, when one tank goes empty and changes to the reserve tank, the regulator sends a signal to the led causing it to illuminate indicating that one tank is empty and changeover has occured. The led draws next to no current. It's a pretty simple thing to rig up.
Paul Mayeux
A&P Vintage Trailer Works, Inc.
AirForums #1565
WBCCI #7162
Heart of Texas Camping Unit
Paul Mayeux is offline   Reply With Quote
Old 07-14-2006, 03:41 PM   #31
Airstreamin and luvin it
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
Tanks
A friend of mine has a Westfalia and it has a digital readout for the propane tanks in his monitor.I wish I could get one of those put in instead of what I have now.
It would just give me one more step to the Kingdom of laziness.
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
Devoman is offline   Reply With Quote
Old 07-14-2006, 11:32 PM   #32
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
The tank cover creates a little problem... but we always used to pour a cup of warm water over the tank ~ watch the condensation work (especially in the cool of the day...) and visually see how much fuel was left. But I have always felt that when I begin to "smell" the propane in the galley, then I know it is nearly out!
CaddyGrn is offline   Reply With Quote
Old 09-02-2006, 12:11 PM   #33
Images: 59
Originally Posted by bhayden
I'm betting the "clear" tanks are filament wound fiberglass. I worked in this industry (giant tanks) for a while and they are very reliable "old school" technology. I think the only reason they haven't been used for small scale operation is cost.
-Bernie
I saw one of these at the state fair yesterday. Pretty neat, you could see the propane level easily.
Two manufacturers have DOT exemption for outdoor use of these cylinders, the one mentioned above, Lite Cylinder of Sweden and Tennessee, and Ragasco of Norway. Both were tested extensively before gaining approval.
The cylinders may be safer than steel when exposed to fire because the poly liner melts, letting the propane escape slowly through the wound fiberglass shell, rather than suddenly as in a steel tank that ruptures.
They are more expensive than steel, but cheaper than aluminum. About $80 for a 20lb tank.
Old 05-02-2007, 07:29 PM   #34
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
Reading the propane gauge
Can someone please explain how to figure out how much propane is left in the tanks when the indicator on one shows a half green and half red stripe? Does this mean the main tank is half empty and it has not shifted over to the reserve tank yet?
This is on a 2007 Safari 27FB with twin 40# tanks and the auto switch over between tanks.
Thank you.
SilverCottage is offline   Reply With Quote
Old 05-02-2007, 10:02 PM   #35
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
We had that happen last time out. Then the tank swapped over and the smell went away. My understanding is that the "smell" in propane is at a higher percentage when the tank is almost empty. I checked for leaks (soapy water) when we got home and found none. Opened the valve and then turned it off. The indicator stayed green over night. I also refilled my empty tank ($22).
Richard
Old 05-02-2007, 10:57 PM   #36
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Thank you.
If you follow this thread from the beginning you will see lots of hints how to tell what the level of fuel is. Normally when you start seeing the red come up, the tank is getting closer to its empty point. My advice is to check out the tank after a heavy use appliance is running. (Water heater or furnace). You should be able to note a condensation line on the tank, or a cooler portion. Once you find that demacation line, you have found the liquid level. Normally after a heavy use, the liquid will be warmer than the gas. Then take a look at the indicator and you will learn how to relate to the red/green indicator and the level of the tank.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-03-2007, 08:13 AM   #37
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
The first time we ran out of gas, I noticed that the lever was really hard to move manually between the two tanks. Is this normal? I sprayed the lever parts with silicon lubricant. Was this harmful?
I haven't checked it lately to see how difficult it might be to move manually between tanks. I did refill both at the end of the winter so we would be starting out the camping season with fresh, full tanks. (I used the furnace all winter set on 50 degrees to keep interior plumbing from freezing.)
Family of Disney Fanatics
WBCCI# 4821
Propane injection Rik Mechanics Corner - Engines, Transmission & More... 13 09-23-2003 10:34 AM
Flying J Propane Question Pick On The Road... 5 10-26-2002 05:46 PM
Disposable Propane Bottle Safety JaceBeck Our Community 6 07-02-2002 01:15 PM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 03:54 AM
Propane and Electrical Line Protection Tamara Electrical - Systems, Generators, Batteries & Solar 7 06-27-2002 09:42 PM
