Old 09-30-2008, 12:37 PM   #1
Vancouver , B.C.
Propane doesn't work
I am very new here.
The situation is that a good friend has offered me the use of her rural property and 1973 Airstream for weekending if she is not using it.
She just bought it 2nd hand and towed it to her place last weekend, and I'm going tomorrow. She has asked me to look at the system to see why the stove will not turn on.
She was told the propane works, but when she tried it it didn't.
There is a furnace, fridge and stove. I'm primarily interested in getting the stove going.
Where do I start in troubleshooting this system?
I had a cabin once with a simple propane system, one stove and one lamp, but that is all I know about using propane besides the BBQ.
hublocker is offline   Reply With Quote
Old 09-30-2008, 12:41 PM   #2
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Have a pro look at it, they can check the entire system for operation and, oh yes, leaks.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 09-30-2008, 12:47 PM   #3
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Wll the other items work?? If so check out gas valve to stove,should be right under trailer.If not and has new opd tanks ,make sure connector is screwed on tight.If that don`t work call a pro.Dave
easyride is offline   Reply With Quote
Old 10-06-2008, 03:19 PM   #4
Vancouver , B.C.
There was a secondary valve on the line in addition to the tank valve, plus there is a valve on the stove. Turned them on and the stove worked.
Old 10-11-2008, 07:43 PM   #5
Ottawa , ON
I think too that some insects are attracted to gas lines for some reason. There could be nests or an obstruction in the combustion jet.
Unless you find something more obvious such as the points raised in the above posts, it couldn't hurt to disassemble and clean the working end of things...
Old 10-11-2008, 08:10 PM   #6
cameront120's Avatar
1972 25' Tradewind
I was going to suggest looking for secondary valves. I'm glad that it worked out for you. If you are going to try out the furnace, I recommend taking along a propane alarm for your own safety.
North Vancouver, BC
Would this work? Chuck Waste Systems, Tanks & Totes 17 04-16-2008 05:43 PM
Would It Work rebel beck Our Community 5 08-09-2006 09:51 PM
they work....... another project Electrical - Systems, Generators, Batteries & Solar 3 11-30-2003 04:46 PM
How does this work??? thenewkid64 General Motorhome Topics 7 07-21-2003 08:58 PM
Would this work on an A/S? Pahaska Off Topic Forum 5 12-13-2002 02:44 PM
