Old 05-22-2019, 03:03 PM   #1
ASLover
2007 25' Safari FB SE
Louisville , Kentucky
Propane connections for auxiliary devices
I am new to AS. We have a 2007 25 safari SE. it does not have a low pressure disconnect and I was thinking about adding one. After reviewing all the threads I am now thinking of just using a 1 input and 2 output high pressure Y and connecting my grill or generator directly.
https://www.amazon.com/DOZYANT-Propa...-1-spons&psc=1
I know my auxiliary devices wont automatically switch over when the tank is empty and I will have to manually switch the auxiliary devices. Any other down side to this method?
Trying to keep it simple.
Thanks in advance!
gregshade is offline   Reply With Quote
Old 05-24-2019, 09:20 AM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I do not know your setup but we are talking low pressure here, downstream of the regulator. So when you switch the regulator to the other tank, manually or automatically, your low pressure piping is switched.
I use my LP connect almost every trip but have never been bothered by disconnecting the grill when I want to run the generator. I am not even sure of whether you can run a device in addition to the generator simultaneously. If you had a regulator on the generator and ran it off a high pressure T, I am sure that would never be a problem. But mine works fine off the low pressure connection on the trailer.
Larry
lsbrodsky is offline   Reply With Quote
Old 05-24-2019, 09:27 AM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
My grill and generator both run off of low pressure. I put a T fitting in where the flexible hose from the regulator connects to the copper tubing to the trailer and mounted a quick disconnect there. I don't think you could run the generator and anything else that needed much flow at the same time so I just disconnect the grill and connect the generator when I use the generator. Of course you have to have a generator and a grill that run off of low pressure. I think most of the generator conversions do, but some grills want high pressure. To use one of them you have to remove the grill regulator.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Honda 2000 propane generator connections hirstpb Generators & Solar Power 12 12-28-2015 08:14 PM
Propane auxiliary connection rooksg LP Gas, Piping, Tanks & Regulators 5 07-12-2015 12:32 PM
Propane auxiliary bottles joelisac Winter Living 1 11-11-2008 09:33 PM
Deer alert devices Minnie's Mate Tow Vehicles 33 11-01-2008 01:27 AM
Anti-sway Devices MURPHY4385 Hitches, Couplers & Balls 7 05-21-2007 12:48 PM
