Old 10-01-2005, 08:09 AM   #1
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Propane/CO detectors
Has anyone installed these detectors themselves? I would like to order one of each; however, Camping World wants $102.00 each to install. That leaves me to ask, "how hard can this be?". We have replaced all of the lights in the Argosy ourselves. Is this something we could also do ourselves? I know they work on the 12V system. I have 12V outlets all over the trailer. Could one of those be refitted for this detector?
juel is offline   Reply With Quote
Old 10-01-2005, 08:15 AM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
The placment is key for propane detectors. Keep them low. Propane is heaver then air and will sink to the floor or low point. Yes you can do it yourself... have fun
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 10-01-2005, 09:02 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I have been looking to add a CO detector to my unit. I saw this unit at Home Depot and was going to get it. It is battery powered which means I would not have to tap into a 12 volt wire in my trailer. It would also not be draining my battery when the trailer is not in use. I will most likely relocate my existing smoke alarm (battery powered) to the kitchen and put this unit in the sleeping area. Any comments on this type of unit?
http://www.homedepot.com/prel80/HDUS...4+3842&pos=n25
The link in preview is not working, but the unit is:
Kidde
Battery-Operated Voice-Alert CO and Smoke Alarm
Model 900-0102
Richard
Old 10-01-2005, 02:08 PM   #4
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I put one of these in but minebut it is powered from the onboard deep cycle battery. Took all of about 30 minutes. I mounted it under the dinette on the top of the kickplates about 20" from the battery. The stove, furnace, fridge and propane lamp are all up front anyway. Kinda out of the way and you have to look for it to see it. I can post a picture if anyone is interested. I sleep a little easier knowing its there.
FF
P.S.: Congrats on your 100th post Rich!!
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 10-01-2005, 03:17 PM   #5
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I installed a LP detector, tied into 12v, in the kitchen cabinet near the floor, because LP sinks. I installed it in there because I figured if the water heater, stove, or fridge leaked, it would sniff it out first if it was in the cabinet with them. The WH is in the closet right next door to it. Very easy to install, I just had to cut a thin piece of plywood with a hole for the detector, and mount it in the cabinet, then spice into the wires that were already there.
I installed a CO detector, battery operated, on top of the bathroom cabinet. This puts it almost directly above the furnace. CO rises, and so this should catch it if the furnace produces any. It's just velcroed to the wall.
I also sleep better knowing they are watching out for stuff I either cannot, or might not, notice.
Stephanie
Old 10-01-2005, 03:56 PM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Kidde
Model 900-0102
azflycaster,
There is supposedly a difference between the RV rated dectectors and the home rated ones...dunno what the difference is...I use a home rated one with the digital read out, if it is sensing CO I want to know how much!
Aaron
WBCCI #XXXX AIR #2495
Old 10-01-2005, 05:29 PM   #7
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Isn't there a difference between a CO2 detector and a propane gas detector?
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 10-01-2005, 05:37 PM   #8
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Ken,
To the best of my knowledge, CO (carbon monoxide) detectors are different from Propane detectors. I have a dual fire/carbon monoxide detector and am contemplating replacing my nonfunctioning propane detector that came in my '86 Sovereign.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 10-01-2005, 05:51 PM   #9
Ken J's Avatar
Durango , Colorado
Images: 14
Thats what I thought - so you probably should have both if you really want to be safe.... to my knowledge, they do not make a battery powered propane gas detector.....
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 10-01-2005, 06:01 PM   #10
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Juel, They are very easy to install, just be sure to install the LP detector at a low point as others have said. I just found a 12 volt wire and wired into it. I would suggest a rv carbon monoxide detector before a home one.
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 10-03-2005, 12:47 AM   #11
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
Some useless trivia...
Raid Ant & Roach Spray sets off the LP detector.
SilverRanger is offline   Reply With Quote
Old 10-03-2005, 09:37 AM   #12
Ken J's Avatar
Durango , Colorado
Images: 14
Now we know how to test them
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 10-03-2005, 11:56 AM   #13
2002 25' Safari
Dewey , Arizona
Images: 62
Ken,
My wife tested the smoke detector last weekend with a steak in the broiler. Works great, tastes great too!
Richard
Old 10-03-2005, 12:26 PM   #14
Ken J's Avatar
Durango , Colorado
Images: 14
Cool - all these ways to make sure our safety equipment works! ......
I like it!
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Suburban Furnace recall !!! NewStreamer Furnaces, Heaters, Fireplaces & Air Conditioning 34 11-26-2015 03:29 PM
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
Stealth safety equipment? Stefrobrts General Interior Topics 8 04-18-2004 06:13 PM
LP Gas/Carbon Monoxide Detectors Joseph O. Smith LP Gas, Piping, Tanks & Regulators 28 11-02-2002 01:22 PM
Smoke Detector ViewRVs Airstream Motorhome Forums 7 09-02-2002 07:57 PM
