Old 11-22-2005, 07:55 PM   #1
1972 25' Tradewind
Wentworth , South Dakota
Propane + Butane
When traveling from up north where we use propane to the South where they use butane is there a problem if you mix the two.
Danetree is offline   Reply With Quote
Old 11-22-2005, 08:18 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Never realized there was a difference...I get my tanks filled in the south all the time and have never had issues...most propane contains at least some butane
Aaron
WBCCI #XXXX AIR #2495
Old 11-22-2005, 08:34 PM   #3
Images: 59
The two gases are different and will boil off at different rates. Propane boils at -41°F, while n-butane boils at +31°F.
If you blend the two, and operate in a cold climate, the propane will boil off (and power your furnace) leaving behind mostly butane.
If you are in a warmer climate it will not matter.
Propane injection Rik Mechanics Corner - Engines, Transmission & More... 13 09-23-2003 10:34 AM
Flying J Propane Question Pick On The Road... 5 10-26-2002 05:46 PM
Disposable Propane Bottle Safety JaceBeck Our Community 6 07-02-2002 01:15 PM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 03:54 AM
Propane valve leak Dbraw LP Gas, Piping, Tanks & Regulators 3 06-14-2002 06:12 PM
