Old 08-28-2016, 02:06 PM   #1
1974 27' Overlander
Baltimore , Maryland
Propane Bracket Spacer
74 Overlander. I am missing the spacer that goes between the top threaded piece that you crank down on and the lower notched piece that pushes down on the propane bottles.
Out of doors mart sells the threaded and the notched piece, but not the spacer that goes between them.
http://odmrv.com/catalog/index.php?m...roducts_id=275
There's a picture of what I'm talking about here:
http://cdn.blog.rvshare.com/wp-conte...225.jpg?de6dcd
Anybody know what this part is called or where I might locate one?
1974 Overlander In Progress
TheGreatleys is offline   Reply With Quote
Old 09-02-2016, 11:07 PM   #2
1973 25' Tradewind
Reno , Nevada
On mine, I believe that the hold down was at the top of the collar not below.
DiHrdBowTi is offline   Reply With Quote
Old 09-02-2016, 11:22 PM   #3
1973 25' Tradewind
Reno , Nevada
Here is a pic although not a very good one.
Phil N Lisa Baker
Reno NV
1973 25' Tradewind
2007 GMC 2500 HD SLE Classic Crew Cab Duramax
Old 09-11-2016, 09:20 PM   #4
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
<snip>
It's called about six inches of aluminum or stainless steel tubing, and you can get it at a decent hardware store. Check to make sure that it's large enough inside diameter to go over your threaded hold-down rod.
Or, the easy way, per Die Hard Bow Tie, is to rearrange stuff like so:
spacer Dan@LED4RV Commercial Listings 0 12-05-2014 03:01 PM
a thin spacer between the batteries and the bottom of the battery box? DJW Electrical - Systems, Generators, Batteries & Solar 5 11-04-2014 03:08 PM
Fit my window today- spacer bar issue deelind Windows & Screens 8 10-11-2010 05:49 PM
Is this a needed spacer for the floor boards? 2333 Repairing/Replacing Floor &/or Frame 4 11-24-2009 08:07 PM
Spacer on exhaust manifold needs replacing. rdm Mechanics Corner - Engines, Transmission & More... 30 11-19-2002 04:14 PM
