Old 07-11-2015, 07:03 PM   #1
2014 25' FB Flying Cloud
eliot , Maine
Question Propane auxiliary connection
During our latest trip, I connected via the quick disconnect to our trailers propane tanks. Unfortunately, there was no gas directed to our grill. I tried both tanks, all tanks and still got nothing. The grill did work using the small propane bottles. Has anyone experienced this before? Do I bring it back for service(still under warranty)
rooksg is offline   Reply With Quote
Old 07-11-2015, 07:11 PM   #2
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
Does your grill have a built in regulator? If it does then it will not work with the "low pressure" output of the Trailer. Basically you can only have 1 regulator in line, if you have 2 then the propane won't flow. Many grills can be adapter to remove their regulator....
Sorry for the short response, hope this helps.. If you post the details of your grill then we can help more.
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 07-11-2015, 09:23 PM   #3
1973 31' Excella 500
Marysville , Washington
I'm not sure so verify: It's my impression that you can position your quick disconnect BEFORE the trailer's regulator. In other words, between the trailer's tank and the trailer's regulator. This would then be a "high pressure" supply that the grille is looking for. As Gsmblue has indicated, two regulators (between the tank and the appliance) is one too many.
Important: Verify as I am not sure.
Not Done is offline   Reply With Quote
Old 07-11-2015, 09:40 PM   #4
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
A problem I have seen is that the quick disconnect fittings are made in two varieties, low pressure and high pressure. I bought one from Camping World that was labelled and the valve was marked low pressure but it was in fact a high pressure fitting. If I remember correctly it mated with the low pressure fitting on my grill hose but the male fitting on the hose would not actuate the shutoff built into the female fitting I bought. I bought another fitting from a different source and it worked.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 07-12-2015, 12:17 PM   #5
eliot , Maine
Thanks! I was originally hooked to a webber q1200 but then switched to a regular Coleman propane stove to avoid the second regulator, still no gas. There is no regulator on the stove.
Old 07-12-2015, 12:32 PM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Each quick connect has a shut off lever that locks the connector so it can't come apart when gas is flowing. Are you sure they were all in the locked position?
2012 Dodge Durango Hemi/AWD
Wayne&Sam is online now   Reply With Quote
Gas connection for propane Wayne Clamp LP Gas, Piping, Tanks & Regulators 35 08-30-2016 03:42 PM
Propane grills for low pressure connection lakeviewerie LP Gas, Piping, Tanks & Regulators 9 11-18-2012 06:22 AM
Int'l Bambi 19' External Propane Connection? jambie 2005 and newer - Bambi all models 1 03-06-2011 07:28 PM
Propane auxiliary bottles joelisac Winter Living 1 11-11-2008 09:33 PM
Auxiliary catalytic heater bhsl8 Furnaces, Heaters, Fireplaces & Air Conditioning 30 07-16-2006 03:41 PM
