Old 09-30-2014, 10:53 AM   #1
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Propane auto shut off reset
I had my furance out for maintenance and bench work and i think i have tripped the auto shutoff (ops) on the regulator. What steps do i take to reset the auto shut off? (I cant even get the stove burners to light and with burner control open im getting no propane smell)
mayco is online now   Reply With Quote
Old 09-30-2014, 11:40 AM   #2
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
I wind up turning everything off, including the cylinders, then disconnecting the lines from the cylinders. Now reconnect the lines and SLOWLY turn on one (or both) of the cylinders.
At this point, the propane in the lines may have been evacuated, pressure reduced, or air/propane mixture disturbed, so auto-striking appliances like fridge and water heater may give you some trouble initially. Help this out by turning on the stove top and use a match to get the flames started. Once they're burning nice and blue, you should have fewer problems with the auto-strike on fridge and water heater.
Lynn
WBCCI 21043
eubank is online now   Reply With Quote
Old 09-30-2014, 12:17 PM   #3
mayco's Avatar
Thanks, i did exactly what you said and it fired tight up, thank you.
Propane Gas Detector Went off Last Week-Turns Out NOT the Propane breezyway Electrical - Systems, Generators, Batteries & Solar 4 08-16-2014 08:56 AM
Radio auto off problem Teamaron Sprinter and B-van Forum 12 09-17-2013 09:36 PM
Inline Propane Shut-off Valves?? SLNugget LP Gas, Piping, Tanks & Regulators 8 09-14-2012 10:52 AM
What temperature should the propane shut off? Getahobby Water Heaters, Filters & Pumps 2 08-19-2012 11:21 AM
Shut off valve, 1992 30' Motorhome dwc Mechanics Corner - Engines, Transmission & More... 0 07-01-2002 04:50 AM
