Old 07-11-2015, 03:07 PM   #1
2015 27' FB International
Newmarket , Ontario
Propane Alarm Stays On with Battery Disconnect
I have a new 2015 27FB International that we have just completed a 2 week shakedown trip.
When putting it into my rental storage space I used the battery disconnect to ensure that there were not any parasitic power drains. On returning to the trailer the next day I noticed that the propane alarm was still active and turned on. Is this normal?
Is there anything else that stays active even though the battery disconnect has bee used?
Should I pull the fuse or physically disconnect the battery at the battery box?
Mike
Newmarketca is offline   Reply With Quote
Old 07-11-2015, 03:11 PM   #2
Gainesville , Florida
Alarm is hot wired to battery for safety.
Old 07-11-2015, 03:13 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Yes, normal operation. The detector is hard wired and can not be turned off without disconecting the battery terminals.
MICHAEL
Old 07-11-2015, 03:15 PM   #4
Newmarket , Ontario
Supper - Thanks for answering so quickly! I will disconnect the battery at the negative terminal so that they don`t go dead over the next two weeks while in storage.
Mike
Old 07-11-2015, 03:15 PM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Don't— unless you also physically disconnect the propane cylinders. As long as the cylinders are connected, propane can leak whether the power is on or off, so it makes sense for the LPG detector to remain on whether the power is on or off.
But with the cylinders disconnected, it's not possible for propane to leak inside the trailer, and so it's quite all right to disconnect the alarm as well.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-11-2015, 03:20 PM   #6
That's the safety part, good point!
Old 07-11-2015, 03:20 PM   #7
Newmarket , Ontario
Good Point! I had turned the cylinders off but should also disconnect the pig tails.
Old 07-11-2015, 03:51 PM   #8
lewster's Avatar
Naples, FL , Hood River, OR
Placing the LP detector into the battery disconnect circuit is a simple job. Locate the positive bus bar (it's the one below the disconnect solenoid with the small circuit breakers) and you'll see a single usually black wire with a small in Lind fuse holder. This is connected directly to the copper strip on the top of the bus.
If you move this wire off the copper strip ( which is energized directly from the battery and is not part of the disconnect circuit) to a connection below the copper bar, it will now be in the disconnect circuit.
A 3/8" nut driver is the only tool you need.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 07-11-2015, 03:56 PM   #9
Newmarket , Ontario
Thanks Lew! Might be a whole lot easier that disconnecting the battery every time I put it into storage.
Mike
Old 07-11-2015, 04:38 PM   #10
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
That is essentially what I did. My wiring change was a little more involved because of the location of the connections, but I put the propane detector on the trailer side of the disconnect switch rather than the battery side where it was. I put the switch in store and shut off the propane but I don't disconnect the pigtails. I figure that the valve on the tank should work, and if it didn't and the propane detector went off, the battery would probably be dead from the alarm before anyone noticed it. When I come back to the trailer I turn on the store/use switch and don't turn the propane on until later.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 07-11-2015, 04:52 PM   #11
dznf0g's Avatar
Oswego , Illinois
Al
Yup.....me too
-Rich-
Old 07-13-2015, 05:29 PM   #12
2002 25' Classic
Kalama , Washington
Might not be right, but...
Mike - Our '02 does/did the same thing. Using one side of the, 'If a tree falls in the forest…' logic, I cut the power wire at the detector (inside the closet) and crimped on a coupling that I disconnect during storage. I saw no benefit in having the alarm scream unheard until it drained our batteries (at which point it is just as silent as removing the power from it selectively). Cat skinning offers a few choices. Great forum to get ideas!
Brian
nwclassic is offline   Reply With Quote
Old 07-13-2015, 05:49 PM   #13
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Brian
Interesting solution. Any pics?
SteveSueMac is online now   Reply With Quote
Old 07-13-2015, 11:26 PM   #14
2002 25' Classic
Kalama , Washington
No pix, but easy to visualize: Our detector is mounted below the closet door. The closet floor is hinged allowing access to the (detector) back where the power wire joins it. Go to any auto parts store and ask for 12v wire fittings. They are usually on a display carrousel. They are colored for wire size. If you cut off a half inch of your wire, you can hand it to the salesperson and say, "I want to join two pieces of this with a coupling I can take apart." You'll be sold a bag of couplings that have a male and female half. Strip each end. Crimp each half (buy stripping/crimping pliers?). Push them together. Pull them apart. Repeat. Presto!
Hope this helps.
HELP! Can't turn off propane alarm!! Lily&Me LP Gas, Piping, Tanks & Regulators 21 04-27-2018 08:47 PM
To disconnect or not to disconnect urnmor Towing, Tow Vehicles & Hitches 36 02-22-2017 10:24 AM
78 Sovereign: batter recharger\transformer puzzle page.crow Batteries, Univolts, Converters & Inverters 0 04-09-2009 08:57 AM
Propane Gas Alarm/Detector Wiring campadk Electrical - Systems, Generators, Batteries & Solar 4 05-02-2007 06:16 PM
