Old 07-13-2015, 11:57 PM   #15
1974 Argosy 20
Kooskia , Idaho
Things that can take battery power with the USE/STORE switch in Store mode:
1. Propane detector
2. Inverter (if equipped and turned on)
3. Power jack and lights on jack
The propane detector does not take a lot of power, but if left on with connected batteries for a month or more can discharge batteries. I recommend total disconnection of the batteries (negative terminal wires pulled) for storage of over a month, and that assumes the batteries are fully charged when put into storage. My definition of "fully charged" is having been left plugged in in USE position for at least 24 hours with any single or three stage charger.
Old 07-14-2015, 05:30 AM   #16
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Yes, helpful description.
Also good suggestion on disconnecting negative battery cables for long term storage...
Old 07-14-2015, 05:42 AM   #17
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Alarms
I would suggest purchase of an individual propane alarm and placing it inside the trailer, especially if you turn off the hard wired detector. These battery powered independent units last a long time, but can prevent a potential disaster should there be a propane leak....tanks on or off.
The other idea is to place a battery tender on the battery when in storage... not always possible I understand, but may be better for the batteries as well.
And, if a CO alarm can be included in the individual unit...better still. Odorless gases such as CO can be deadly, not in immediate death, but in impairment of activity/decision making in small doses. And around trailers we need to be very attentive to what we are doing.
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 08-17-2015, 12:38 PM   #18
2015 27' FB International
Newmarket , Ontario
I realise the propane alarm does not use a lot of power but I am curious on the battery impact of leaving it on for a week or so. Does anyone know how much of an amp the propane alarm draws?
Thanks Mike
Newmarketca is offline   Reply With Quote
Old 08-17-2015, 02:39 PM   #19
1974 Argosy 20
Kooskia , Idaho
On my 2014 FC 20', the propane detector takes 0.06 amp.
Old 08-17-2015, 04:07 PM   #20
field & stream's Avatar
2008 23' Safari SE
2007 Base Camp
Santa Ynez , California
idroba -- Thanks. I have been trying to isolate a 0.07 draw on the battery in my Basecamp, and I think you found it !
field & stream is offline   Reply With Quote
Old 08-17-2015, 04:16 PM   #21
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
The LP detector also seems to alarm the presence of methane, which we found out when our Labrador Retriever slept on the floor with his tail end next to it. His periodic emissions would trip the alarm. One alert, and I'd have to turn him around, and then set up the dinette bed for him.
No WD, but a great DW!
robert claus is offline   Reply With Quote
Old 08-18-2015, 06:07 AM   #22
Newmarket , Ontario
Super - Thanks for the amp readings! Two weeks sitting in the storage yard would have a significant hit on the battery.
Mike
Old 08-18-2015, 07:17 AM   #23
dznf0g's Avatar
Oswego , Illinois
I have been trying to reduce/eliminate parasitics for storage with a 15 watt watt solar panel.
The only thing operational with store switch off are:
Brake actuator
Trimetric battery monitor (necessary for solar monitoring) = 30mA when display off
Morningstar controller = 35mA with no function (night)
Converter (LED flashes with no 120v applied, but obviously hooked up to batts) = I can't find how much draw while off in any literature
These are the only things operational that I can find which contribute to my approx. 165mA draw. So I haven't identified about 100mA of draw.
1) does anyone know if the actuator board??? has a parasitic draw?
2) does anyone know how much draw an Iota 55DLS converter has while unplugged from 120V?
-Rich-
Old 08-18-2015, 03:53 PM   #24
Nomad518's Avatar
2001 25' Safari
Vancouver , Washington
Now THAT'S funny!!
Nomad518 is offline   Reply With Quote
HELP! Can't turn off propane alarm!! Lily&Me LP Gas, Piping, Tanks & Regulators 21 04-27-2018 08:47 PM
To disconnect or not to disconnect urnmor Towing, Tow Vehicles & Hitches 36 02-22-2017 10:24 AM
78 Sovereign: batter recharger\transformer puzzle page.crow Batteries, Univolts, Converters & Inverters 0 04-09-2009 08:57 AM
Propane Gas Alarm/Detector Wiring campadk Electrical - Systems, Generators, Batteries & Solar 4 05-02-2007 06:16 PM
