Old 02-04-2013, 09:12 AM   #1
2009 25' FB Flying Cloud
Portsmouth , Rhode Island
Problems with PROTECHTOR
Not sure what forum for this, but the red light in the Protechtor panel in my 2009 Flying Cloud is on all the time. Following recommended test procedure of holding test button in for 5-6 seconds does not do anything. Have spent several hours in the trailer last few days and no smell of propane and all seems to be working as it should. Thanks for any thoughts.
Jack
JackRenner is offline   Reply With Quote
Old 02-04-2013, 09:43 AM   #2
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Jack
According to the manual
http://www.atwoodmobile.com/manuals/...%20LP%20RV.pdf
A solid red light indicates a Low Power or microprocessor failure. Atwood Service should be contacted.
815-877-5700
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 02-04-2013, 09:59 AM   #3
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
If you batteries are not holding a full charge, the propane detector will begin to fault and the alarm will sound.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 02-04-2013, 10:03 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
815-877-5700
Given the range of operating voltages, it would only display a "low power" light if everything DC in your trailer was dead, too. So it's probably the microprocessor. Mine crapped out on me on my very first camping trip after I accidentally kicked it. The fix was surprisingly easy…
Disconnect the power to it entirely, and wait about a minute. Pulling the fuse is the easiest way, if you can find the in-line fuse. If you can't find the fuse, the battery isolator switch should work as well. After a minute, hook it back up, and see if the light goes back to flashing green every 8 seconds like it's supposed to. If it does, you're good. If not, plan to replace the unit with a new one.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-04-2013, 10:42 AM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We had one in our VW camper a few years ago that would go off spraying an aerosol can near it, or if the battery was low.
The one in our new trailer was warning when we bought it, they replaced it and a few days ago it was beeping. Reset it by holding in the button, vacuumed it out in case dust had settled in there, good to go.
They're kind of sensitive but probably worth having in there.
doug k
