Old 08-20-2014, 06:49 AM   #1
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Pop like a gunshot
Slightly concerned.
Just started cooking breakfast, DW got one of the burners to light but not all. We shut everything down. All windows are open an fans on. Let it air out a few minutes then lit front burner with a lighter. All is well. A few minutes later we hear a pop like a gunshot. I dot smell any propane and we're packed so tight here I can't tell if it came from us or someone next to us but one if our neighbors thought we had slammed a cabinet really hard.
There's definitely nothin wrong in the trailer.
I checked the electrical pedestal to see if maybe that blew up - it's fine. We smell no propane.
Thoughts and suggestions most welcome??
Old 08-20-2014, 06:53 AM   #2
W , New England
By the way - the sound was definitely not from inside the trailer. If that helps any...
Old 08-20-2014, 06:54 AM   #3
W , New England
Also - I typed too fast and autocorrect made me sound ignorant....
Old 08-20-2014, 07:14 AM   #4
Wayward's Avatar
Cary , North Carolina
Check all the rubber lines around the tanks and regulator. An over pressurized or defective rubber line would pop like that.
Also a pressure relief valve will pop when it kicks in. I never heard one so cannot tell you how loud it would be.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 08-20-2014, 08:13 AM   #5
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Check batteries. When they blow, it sounds like a gunshot.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 08-20-2014, 08:15 AM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Might have been anything. From a neighbor, kids playing, etc.
MICHAEL
Old 08-20-2014, 08:29 AM   #7
W , New England
Thanks everyone - just found out it was our neighbor's battery exploding! DW and I were taking a walk and noticed a big piece of black plastic on the ground. Sure enough, it matched like a jig saw piece on our neighbor's battery box. The CG owner had been walking up and down our row trying to figure out where the "bang" came from and I showed him the plastic piece. He opened up the neighbor's shattered battery case and the battery itself had clearly exploded. The water cover on one side was nowhere to be found and the top of the battery was ripped from the sides. Must have been one healthy explosion!
Before finding this, I went to my propane tanks - the circle was still green which I thought might be a good sign - if a line had "popped", the tank would presumably have emptied (and we smelled no propane and our propane detector didn't go off). I also traced all the lines from the tanks back to the point the enter the belly pan - no splits, no cracks, no broken joints - so I was still worried something might have popped inside the belly pan. How would you know??
At any rate - while I feel bad for my neighbor, I'm so relieved to know what it actually was! My neighbor on the other side of me has the RV mechanic looking at his rig now because his DW has been smelling smoke the past few nights and thought that bang was in their trailer. And good for them for not taking any chances with that! Hopefully it's nothing, but better safe than sorry!
Thanks all for your thoughts here and the PMs. Very much appreciated!
Oh - and check your battery water often!! :-)
Old 08-20-2014, 08:32 AM   #8
W , New England
Spot on! I know that now! :-)
Old 08-20-2014, 08:33 AM   #9
AWCHIEF's Avatar
Images: 33
Glad you found the answer to the mystery. A bit of piece of mind in that.
MICHAEL
Old 08-20-2014, 08:34 AM   #10
W , New England
Thanks - you said it! Quite a relief!
Old 08-20-2014, 09:37 AM   #11
Tincampers's Avatar
Sneedville , Tennessee
Gotta love auto-correct. I predict it will start WWIII.
Tincampers is offline   Reply With Quote
Old 08-20-2014, 11:48 AM   #12
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
So, the question in my mind is, what makes your battery explode like a bomb?!!
Stephanie
Old 08-20-2014, 11:53 AM   #13
RKL1954's Avatar
2015 25' FB Flying Cloud
1966 28' Ambassador
Vancouver , Washington
Batteries usually explode either because they are in an unvented space and a spark occurs. Or they are being overcharged and excessive hydrogen gas is vented (and again a spark occurs). Very scary!
RKL1954 is offline   Reply With Quote
Old 08-20-2014, 11:57 AM   #14
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Originally Posted by RKL1954 View Post
Very scary!
Particularly since mine is under my bed!
Stephanie
Why Collect Pop Tabs? fireflyinva WBCCI Forum 19 01-21-2014 11:37 AM
Why is My Water Coming Out Like Soda Pop? Fly at Night Fresh Water Systems 14 06-06-2012 06:10 PM
"Jiffy pop" 1959 camper shell tumbleweed Commercial Listings 3 07-22-2004 05:12 PM
What size drill bit for the 1/8 inch in pop rivits? TBKP's Overlander Ribs, Skins & Rivets 3 07-24-2003 11:21 AM
