Old 08-20-2014, 12:20 PM   #15
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by Stefrobrts View Post
So, the question in my mind is, what makes your battery explode like a bomb?!!
Batteries venting hydrogen might cause an explosion in the battery box, but normally won't cause the battery itself to explode. For that to happen, there has to be ignition INSIDE the battery.
My best guess is that the missing cover that you couldn't find was already missing from the battery, not as a result of the explosion. Then when the spark ignited the hydrogen inside the battery box, the flame back-flashed into the battery through the open fill ports. As the fire tried to expand inside the battery, it expanded faster than the flame could come out the fill ports, and BOOM! That's what an explosion is, a very fast fire that has nowhere to go fast enough to get out of its own way.
Lesson to take away from this (even if it is speculative on my part) never charge your batteries (or use them, for that matter) with the fill covers off.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-20-2014, 01:04 PM   #16
Wise Elder
Jammer's Avatar
2010 30' Classic
It's not unusual for batteries with a shorted or frozen cell to explode when being charged or if they are in parallel with a good battery.
Old 08-21-2014, 08:38 PM   #17
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Was that an SOB or Airstream that had the failure?
Due diligence on batteries... duly noted. Also, a 'spark' can come from poor terminal connectivity... clean your terminals and the clamps...!!!
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-22-2014, 06:23 AM   #18
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
SOB - plastic battery case blew apart when the battery blew up.
Old 08-22-2014, 08:39 AM   #19
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I left my 99 in storage 700 miles away, plugged into shore power (converter is on a timer though). I was halfway home when I realized I'd forgotten to check the water in the battery. Two months till I'll be back. Reading this thread is giving me heartburn!
Alan
Old 08-22-2014, 09:07 AM   #20
W , New England
Anyone near your storage location with access? Sorry - didn't mean to cause agita!
Why Collect Pop Tabs? fireflyinva WBCCI Forum 19 01-21-2014 11:37 AM
Why is My Water Coming Out Like Soda Pop? Fly at Night Fresh Water Systems 14 06-06-2012 06:10 PM
"Jiffy pop" 1959 camper shell tumbleweed Commercial Listings 3 07-22-2004 05:12 PM
What size drill bit for the 1/8 inch in pop rivits? TBKP's Overlander Ribs, Skins & Rivets 3 07-24-2003 11:21 AM
