Old 07-08-2015, 05:29 PM   #1
Dallas , Texas
PO "mods" on my '78. What's correct?
Hi all,
I have some questionable work on my trailer done by the previous owner. I'm hoping you can set me straight.
1. The regulator bracket is currently a block of wood. What's the correct bracket?
2. Does this setup look right? The pole seems very flimsy with only a screw/nut holding it at the bottom.
66replica is offline   Reply With Quote
Old 07-08-2015, 07:22 PM   #2
Mission , Texas
Looks like a piece of wood screwed to the tank bracket, my guess to mount a regulator on.
In addition to the center bolt and top bracket, there could be pins at the bottom of the tanks.
nrgtrakr is offline   Reply With Quote
Old 07-08-2015, 07:41 PM   #3
1974 Argosy 20
Kooskia , Idaho
The regulator originally mounted on a cast aluminum extension of the part that holds the tanks down in your photo. Apparently it is broken off and the PO put an L shelf bracket and wood piece to replace it (as best I can see from the photo).
I am not sure that the original cast aluminum tank parts are still available, so you may have to make a better solution than the wood part, maybe out of a fabricated aluminum piece which fits under the hold down bracket and attaches to it in some way. Of course if you can locate the original part, it would be a better solution.
"silver avion" avion C11 airstream "truck camper' "slide-in" aluminum eBay Watch Airstreams on eBay 0 09-14-2013 06:20 PM
Correct Wheels "78" Ambassador Roadrunner Wheels, Hubs & Bearings 2 09-21-2009 03:14 PM
