Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 08-26-2011, 07:09 PM   #1
1969 31' Sovereign
Dawsonville , Georgia
Please Help! Magic Chef Countertop stove low flow
I just recently purchased a 1969 Soveriegn 31'. It has a 3 burner magic chef countertop stove, but all of the gas lines have been removed. I have replaced the lines and I installed a new "camper style" low flow regulator, since there was no original. The stove lights, but has a teeny tiny flame and only enough flow to support one burner. Where the 69's a higher flow regulator? What is the operating pressure for the magic chef model 34?
Thanks a ton!
David
blazeff13 is offline   Reply With Quote
Old 08-26-2011, 08:54 PM   #2
Thanks a ton!
David
The LPG regulator output pressure should be 11 to 13 inches of water column.
Usually it's better to set the regulator closer to the 13.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-26-2011, 09:17 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
David,
I do believe that the 1969 model will have had a higher pressure regulator than the new low pressure camper ones. Find out what the settings are on your current one and if it is adjustable.
Aaron
WBCCI #XXXX AIR #2495
Old 08-26-2011, 09:34 PM   #4
Originally Posted by wahoonc View Post
David,
Aaron
Aaron
Airstream used the same Fisher LPG regulator from the early 60's to the late 80's.
It was never to be set to exceed 13 inches of water column pressure.
Andy 11.8
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-26-2011, 09:55 PM   #5
Ottawa , ON
Mebbe there's a kink somewheres in the gas line.
Or, that juice they add to LP gas to make it smelly, (what's it called again? Oh yeah, thiophene) maybe there is an excess of it in the lines causing a blockage of some kind...
Looking for 3 grates: Magic Chef Model #165 Merlita Stoves, Ovens & Microwaves 17 07-09-2018 05:11 PM
Magic Chef Stovetop - Value denverdingo Electronics & Connectivity 3 08-25-2011 07:36 PM
3 Burner Magic Chef counter-top stove questions blazeff13 General Appliance Topics 0 08-14-2011 07:00 PM
Magic chef oven cathy72417 Stoves, Ovens & Microwaves 0 08-05-2011 07:56 AM
Magic chef oven Airstream76 Stoves, Ovens & Microwaves 15 01-25-2011 11:38 PM
