Old 04-21-2012, 04:54 PM   #1
1978 Argosy 27
Hoover , Alabama
Piping
Looks like I will be re-plumbing the 78.
Everywhere there is a tee there is a stain.
I wonder what you experienced rv folk would recommend?
cford is offline   Reply With Quote
Old 04-21-2012, 05:10 PM   #2
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
PEX pipe and Sharkbite fittings.
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 04-21-2012, 05:29 PM   #3
1978 Argosy 27
Hoover , Alabama
Do you need special tools to make connections?
Old 04-21-2012, 05:32 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
A pvc/pex cutting tool, and if it a push together connection, that is about it. There is a special wrench for the push on, clamp down fittings, which you should be able to get at the same place you get the fittings.
Old 04-21-2012, 05:47 PM   #5
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
You can find the pipe and Sharkbite fittings at any home improvement store. I was able to use ordinary tools to install my Sharkbite fittings.
Thanks, Derek
Old 04-21-2012, 05:58 PM   #6
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Personal preference here - I use pex and clamp-on fittings. I just feel more confident in them and their longevity. You do need a crimp tool for installation though, and they also sell a tool to cut the rings off if you need to make a repair or fix a leak. Tools, clamp rings, and fittings are available where pex and sharkbite fittings are sold too. Take a look at both options and see which you like the best.
Chris
Old 04-21-2012, 10:44 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I used PEX and Flair It fittings. No special tools required to assemble or take apart. You will need a PVC/PEX cutting tool.
TG Twinkie is online now   Reply With Quote
Old 04-22-2012, 12:03 AM   #8
Maniacal Engineer
barts's Avatar
Menlo Park , California
PEX is really the way to go for replumbing. A bit of care in determining piping runs will save money on fittings; brass/bronze fittings are expensive these days, but the PEX is cheap. PEX is reasonably flexible, so installing in existing areas is much easier than w/ copper. Avoid significant torque at end joints. So far I've used the SharkBite push-on fittings; since we're remodeling section by section the kitchen area is still copper.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 04-22-2012, 12:18 AM   #9
danlehosky's Avatar
2012 25' FB Flying Cloud
Gig Harbor , Washington
I like Pex as well. Sharkbite fittings depend on an o-ring seal. While o-rings provide reliable seals, they sometimes shrink or crack and i've seen heavily chlorinated water fatigue or deteriorate the rubber. You may also consider a manifold system where you have a centrally located block with shutoff valves and run individual lines to each fixture. No joints and you can use 3/8" line. All of these systems are much more forgiving in freezing situations than copper
as the plastic will expand without splitting (for the most part). The tubing may impart a plastic taste to the water when new but will not last long.
Dan
TAC
Hope is not a plan.
danlehosky is offline   Reply With Quote
Old 04-22-2012, 06:47 AM   #10
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Charles, the thread seems to be about water plumbing, but your thread is in the LP gas piping forum. Are you wanting to redo the water system or the gas system?
Lynn
WBCCI 21043
eubank is online now   Reply With Quote
Old 04-22-2012, 12:13 PM   #11
1978 Argosy 27
Hoover , Alabama
Dan
So 3/8 is the standard for the system?
c
Old 04-22-2012, 12:14 PM   #12
1978 Argosy 27
Hoover , Alabama
Lynn
I saw the word piping and posted. My bad
I will be reusing the gas lines that are copper and will replace the rest.
