Old 10-11-2019, 05:24 PM   #1
TankerIP's Avatar
2002 22' International
2019 25' Flying Cloud
Pigtail Fitting Size
I want to replace one of my 12" pigtails with a 15". It will make it easier to attach my adapter for a hose to run my grill, same as the setup on my old 22' we lost this year.
I'm trying to figure out what type 1/4" fitting I might have. Now it seems I might have a 3/8 pipe fitting instead. Can anyone confirm this from what they see in the photo I attached, or maybe what they have on their new 2019 FC?
I looked online at the Cavagna Propane Regulator site. It seems the model I have normally comes delivered with a brass fitting adapter screwed into the regulator inlet. My regulator has NO such adapter and the pigtail is screwed directly into the regulator. So.......I have to guess I have the 3/8 pipe fitting pigtail.
Why would Airstream install something that is not standard type of configuration.?
TankerIP is offline   Reply With Quote
Old 10-11-2019, 08:46 PM   #2
2014 25' FB Flying Cloud
I am a fellow Austinite with the same issue. I have a 2014 25FB which also has pigtails with the end of the hose fitting into the tank switch having larger than 1/4 pipe fittings. I just got back from South Dakota where one pigtail developed a leak. I have just started to search for a replacement and have to find the correct part. Let me know what you find and I will do the same. Hopefully, someone else will have a suggestion for us.
Lebthree is offline   Reply With Quote
Old 10-11-2019, 09:38 PM   #3
After briefly considering this I think I am going the 1/4 to 3/8 ntp adaptor route and use standard pigtails. This way I will be able to find a replacement pigtail easier when on the road. Hopefully reducing the size will have no ill effects.
Old 10-15-2019, 10:01 AM   #4
TankerIP's Avatar
What adapter do you think will work? I have not confirmed that the inlet to the regulator is 3/8 pipe thread or 1/4. I need to know what to order.
I tried to call Cavagna but can't get the right number. I checked my Airstream parts manual and it seems they just order the Cavagna regulator with 11" hoses already attached. I looked on Amazon at the Cavagna regulators and those come with an adapter already screwed in. I guess Airstream got a bit cheaper assembly.
Old 10-15-2019, 05:35 PM   #5
TankerIP's Avatar
FIXED - Found hose and Adapter
I went to my Airstream dealer who told me they had the 15" hose and I needed their adapter to make it work. The hose was only $11 (less than online). The adapter fitting was a brass 1/4" Male NPT x 1/4" Female Inverted Flare.
Installing the new hose with the adapter changed the geometry. I had to raise the regulator so that the new fittings would screw in straight(Img #1). Luckily, I had yellow teflon tape for LPG in my toolbox. The pipe fittings need that. I did not have to tape the flare fittings. I checked it all with dish soap mixture. It leaked before I used the Teflon, but not after.
The 15" hose was necessary because of my external hose connector. In order for all to fit in the propane tank cover, I needed to turn the tank at 45 degrees (Img#2).
In case you wonder why all the trouble: I have a table top grill that I like to use, but I want more than a couple of green portable bottles to power it. (Img#3)
ID:	354324   Click image for larger version
Old 10-15-2019, 05:56 PM   #6
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
NPT to inverted flare adapters are available in multiple sizes in most good hardware stores. There is nothing special about these adapter fitting.
Old 10-15-2019, 06:29 PM   #7
TankerIP's Avatar
Aerowood you are right. My problem was nobody could tell me what adapter I needed. I looked at parts manual, called the regulator company, searched online, and checked this forum. I was sure it was simple. I was not going to drive my trailer to Home Depot to solve the problem.
So finally now, if my post is clear, someone will know that they need to get new pigtails for their 2019 Flying Cloud.
Old 10-16-2019, 02:17 PM   #8
Aerowood's Avatar
Arvada , Colorado
Does TankerIP mean Tanker Instructor Pilot? I just retired as a C-130 FE (Civilian)
Old 10-19-2019, 08:19 PM   #9
TankerIP's Avatar
Yes that's correct. Retired many years ago.
Old 11-11-2019, 09:44 PM   #10
Julie-Bob's Avatar
2009 25' FB Classic
Scottsdale , Arizona
I have a 2009 25FB Classic and Im trying to change out both propane hoses. As yours the regulator does not have the brass fitting installed. The old hose could be 3/8 and the new hose could be 1/4. Has anyone solved which fitting will work in the regulator and allow the new hose to be installed? I have gone on line and found regulators and all have a brass fitting installed to reduce down to a 1/4 hose. Need part number of fitting
Bob & Julie # 5587, 4CU in AZ
Julie-Bob is offline   Reply With Quote
Old 11-11-2019, 09:56 PM   #11
Julie-Bob's Avatar
2009 25' FB Classic
Ok more on line work found the following.
Camco Part number 59953 is the fitting that goes between the Camco Regulator and the new hoses.
Propane Pigtail Connector Orifice Size? SilverWind LP Gas, Piping, Tanks & Regulators 2 08-29-2018 05:26 PM
New Pigtail locks up my Sovereign brakes mello mike Electrical - Systems, Generators, Batteries & Solar 15 08-14-2009 11:46 AM
It all worked before I redid the pigtail 72BamaStream Electrical - Systems, Generators, Batteries & Solar 5 01-20-2009 09:17 AM
73 Safari - Need Electrical Pigtail Between Vehicles kadyacres Electrical - Systems, Generators, Batteries & Solar 5 07-05-2004 02:10 PM
'72 Trade Wind Pigtail Schematic igor Brakes & Brake Controllers 3 07-14-2002 04:15 AM
