Old 08-31-2008, 12:50 PM   #1
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
Pictures of quick disconnect gas line mounting.
OK, here is my first post on what I have done to our 2004 25 Classic we just bought. If this has already been done, I apologize. I can also say that if you are using a barbecue unit that has a regulator, your BTU output is way less than what it should be. I tried just connecting the new line to the barbecue unit that had the regulator. You could feel the heat, but you could not see any flames. I then connected a regular camping propane tank (that has higher pressure) to it the way it was supposed to be used. What a difference, You could feel more heat and you could see the flames coming up. So keeping the regulator is a no - no! You need to replace it with a regular valve.
ID:	66611   Click image for larger version
RLS is offline   Reply With Quote
Old 08-31-2008, 02:39 PM   #2
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
You have a regulator at your tanks now - having another at the BBQ only reduces the flow of the gas. You can connect that QD dirctly to the BBQ without a regulator as you are already on the low pressure side.
BTW - there are adaptors at Walmart that connect on the bottom of the regulator and reconnect to your lines that save you from having to cut and flare the tubing - cost under $30.
Nice neat job, bubble test for leaks?
Mike
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 08-31-2008, 09:28 PM   #3
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
Thanks Mike,
Yes!! and noooo bubbles! lol I saw that connection, but for me it was not a good idea. This mounting is to the rear of the wheels, so I wanted to tap in to the gas line as close as possible.
LP Quick Connect for Gas Grill Mod-Streamer LP Gas, Piping, Tanks & Regulators 13 06-10-2015 05:20 PM
Rubber Gas Line Sundance LP Gas, Piping, Tanks & Regulators 4 07-13-2007 06:06 PM
LP gas line question 63air LP Gas, Piping, Tanks & Regulators 5 01-21-2007 10:41 PM
Lost the cooling gas from the line. Astrodokk Refrigerators 1 10-24-2004 10:30 AM
