Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 07-22-2002, 02:32 PM   #1
lbrodsky
Profile:  2001 27' Safari
Springfield , Virginia
Oven gas line broken
Anbody experience this problem. When attempting to light the gas pilot in the Maytag oven of my 2001 Safari, yellow flames started shooting out in my direction...not a fun experience. It had worked fine the last time I used the oven. Upon close inspection, I discovered that the 1/8-inch gas line which comes out of a hole in the back of the oven and connects to the pilot light assembly was broken off at the back of the pilot light assembly (a compression fitting). To fix this, I removed the compression nut, bought a new 1/8-inch compression sleeve and reconnected the line (there was enough play in the line to make the reconnection). This seems to have fixed the problem. Has anybody else experienced a break in this thin gas line at the pilot light connection? I don't store anything in the oven which could bounce around while underway and cause the break, so I can only assume the connection was overstressed when assembled at the factory.
lbrodsky is offline   Reply With Quote
Old 07-22-2002, 03:46 PM   #2
Jim Clark
Jim Clark's Avatar
Profile:  2005 25' Safari
New Orleans , Louisiana
Re: Oven gas line broken
If the line is not secured and bounces around or vibrates as the trailer it could very well faituge and break.
When I rebuilt my unit I found a broken copper propane line which had been repaired with electrical tape and a hose clamp.
First Weekend Shindig @ Topsail First Weekend in Jan.
Thanks Jim, N5TJZ
2005 25' Safari ,AIR# 174
S/V Wandering Spirit
http://airstreamlife.ning.com/profile*/JimClark
Picture Gallery
http://gallery.mac.com/jimclark6#gallery
Jim Clark is offline   Reply With Quote
Old 07-22-2002, 05:01 PM   #3
74Argosy24MH
Profile:  LOST , Hawaii
A few more idiots like that around and we will have to get a license to buy a screwdriver.
74Argosy24MH is offline   Reply With Quote
Old 07-22-2002, 09:44 PM   #4
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Looks like the guy who put in your rear antenna wire was also doing gas lines.....
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 07-23-2002, 03:52 AM   #5
James Schmidt
Profile:  1993 29' Excella
Jonesboro , Louisiana
I had the same thing happen to my gas line on my 93 excello 1000. I opted to remove the range/oven and replace the whole line. The original line was aluminum but I replaced it with copper. This happend about 2 years ago. Have not had any trouble since. Sounds like it may be a problem for lots of folks. Too Bad!!!!
James Schmidt
29 ft Excello 1000
97 Expedition/Hensley Hitch/
McKesh mirrors
James Schmidt is offline   Reply With Quote
LP supply line uwe LP Gas, Piping, Tanks & Regulators 8 09-17-2006 04:12 PM
servicing gas part of refrigerator nickcrowhurst Refrigerators 3 02-21-2006 07:46 AM
Threaded Gas Line Dope Navigator LP Gas, Piping, Tanks & Regulators 7 03-24-2004 07:16 PM
Gas Furnace ketchumwt Furnaces, Heaters, Fireplaces & Air Conditioning 4 12-04-2003 12:46 PM
gas line to water heater bken Water Heaters, Filters & Pumps 0 05-03-2003 08:11 PM
