Old 02-14-2004, 03:27 PM   #1
phred's Avatar
OPD valves for 40 pound aluminum bottle
A friend has a mid to late 70's 30 foot trailer with aluminum 40 pound propane tanks. Does any one know a supplier for the new OPD valves for these aluminum tanks. They are longer than the OPD valves for the steel tanks.
Any help would be appreciated.
Fred
phred is offline   Reply With Quote
Old 02-14-2004, 05:20 PM   #2
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Fred, just take the tanks to your local dealer. If they don't have the valves on hand, they can order them without rocket science.
Lynn
WBCCI 21043
Old 02-14-2004, 05:39 PM   #3
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
The appropriate dip tube lengths are listed here.
Maurice
Old 02-14-2004, 05:49 PM   #4
J&C
J&C's Avatar
2002 31' Classic
Hillsboro , Texas
Images: 11
40 Pound Aluminum LP cans
Fred,
If you're referring to the horizonal LP cans, these have been exempted from OPD retrofits. Contact Airstream, they will send stickers for the cans. If they are vertical cans, Airstream has the correct/compatable OPD valves and is selling them at a reduced cost.
This past weekend, I took the A/S to a large, rural LP gas center. The gas was $1.50, the empty tank held 38 gallons. I was told to tell the cashier, my horizonal can was a forklift bottle. Their standard charge for forklift bottles was $14.00. I asked if they were sure about this and they said Yes! WOW, I'll go back!
J&C is offline   Reply With Quote
Old 02-28-2009, 02:43 AM   #5
Distantdrummer's Avatar
1975 31' Sovereign
Houston , Texas
OK I know this is an old thread and all But...
What's with this horizontal vs vertical stuff? Forklift bottle discount ????
And what is the current 2009 price for propane per gal /.
And has/is Airstream Inc actually (still) selling anything at "reduced" cost?
__________________________
____ d'drummer ____
...aahh..rumm..pu..tum..tummm...
Distantdrummer is offline   Reply With Quote
Old 02-28-2009, 05:28 AM   #6
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Horizontal tanks were used on some year "limited" 34 models. They are mounted with the diameter axis mounted horizontally under a shroud. They look similar and mount like the ones used on fork lift trucks. They are different in the way they take as they take off the top in gaseous state rather than a liquid state like the forklifts do. You can check the Airstream store at Airstream.com, to see if they still sell them. Most trailers mount the bottles standing up. Aluminum bottles require a speial OPD valve different tha the steel bottles.
Lately, Airstream has been selling their outdated or overstock parts on Ebay rather than bringing them to WBCCI functions and offering them as big discounts. WBCCI functions recently have had reduced participation and Airstream has moved away from using them. It is a business thing to maximize profits by increasing the number of people they are marketing to.
Old 03-02-2009, 05:42 AM   #7
Dan@LED4RV's Avatar
Denton , North Carolina
yes they are differant
Fred
Fred,
Yes they are differant from the steel ones. It has to do with the shape of the bottles.
Click here to see the 40 lbs valves.
The tanks will need to be pressure tested and any company that can do that, will have the tools to change the valves. They most likely won't have the valves for the aluminum tanks in stock.
Dan
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 05-30-2009, 11:56 AM   #8
1972 31' Sovereign
Sussex Co. , Delaware
new OPD valves for 40lb tanks
I highly recommend Wiley and Sons (a propane company) in Milton, DE. Other than some surprise at finding what I thought were 30lb aluminum tanks to actually be 40 lb aluminum tanks, it was pretty quick and easy for them to test the tanks and make the switch. And they were remarkably courteous and professional about it considering I showed up at 4:00pm on a Friday afternoon. The hardest part was finding them...I literally called every number in the phonebook looking. Seeing as Wiley starts with "W" you get an idea how irritating and long that process was. Whole deal--new valves, test, and fill with propane was 69.00 each 40lb tank.
stonyfork is offline   Reply With Quote
