Old 04-15-2002, 11:34 AM   #1
83Excella's Avatar
1983 27' Excella
Airstreamville , Kansas
OPD valve w/sight gauges
I had my LP bottles filled a few weeks ago and the dealer can install and certify by bottles with the new OPD valves but they dont have the sight gauges as mine have now so I elected to just refill them until I can get them with sight gauges, are new valves with a sight gauge available anywhere?
John
83Excella is offline   Reply With Quote
Old 04-16-2002, 07:21 AM   #2
1996 30' Excella
Brighton , Michigan
I had trouble finding the correct OPD valves for my tank also. If you look at the handle on the top of the tank there are several items stamped into the surface, including the tank manufacture. Contact the manufacture for the correct valve for your tanks.
I do have a copy of the April RV Buisness which lists many of the suppliers and will look up the manufacture for you or you can contact Airstream Tech Service hot line for help.
The Tech hot line number is 1-877-595-6505. This is a voice mail system and they will call you back with in 24 hours. Leave the following information when calling
1. your name
2. daytime phone number
3. trailer or motor home
4. model year
5. last 6 digits of your serial number
6. detailed description of the problem
They have helped me on several ocasions including where to get my OPD valves. The local LPG supplier had no idea but was able to order them once I got the information.
apple 1 is offline   Reply With Quote
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 08:45 AM
Followup to valve stem failure dtbw Wheels, Hubs & Bearings 0 10-29-2003 08:40 AM
OPD valves, Sight Gauges & Remote Senders femuse LP Gas, Piping, Tanks & Regulators 1 04-29-2003 07:41 PM
Conflict between OPD Valve & "Fuel Gauge" ? femuse LP Gas, Piping, Tanks & Regulators 0 04-22-2003 11:15 AM
