Old 04-04-2013, 10:17 PM   #1
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
One way to keep the propane tanks secure
I purchased a padlock by BOLT specifically to be used with the Dodge TV. It measures 2" inside the shackle and is now keyed to the TV ignition/door key.
I drilled an oversize hole 7/16" in the top wing nut and 11/32" holes through the aluminum frame bracket of the tank enclosure and the propane valve support. The lower wing nut can not be moved either because of the padlock blocking it's rotation.
A photo can be seen by clicking on the number after the word 'images' below my avatar to the left. The photo was taken in vertical mode, but importing it into the gallery made it lay horizontal.
Old 04-06-2013, 05:40 PM   #2
tkowalyk's Avatar
2013 27' FB Classic
North Wales , Pennsylvania
Images: 11
I like this idea and will retrofit my tanks, and buy a couple of bolt locks for various uses.
Tom
Tom & Lori
2013 27 FB Classic Limited
2016 Nissan XD Turbo Diesel
WBCCI 03288 TAC PA-17
tkowalyk is offline   Reply With Quote
