Old 10-03-2014, 09:44 AM   #1
1982 34' Limited
London , Ontario
On demand water heater
Is anyone using one and if so does it work well
the34ftguy is offline   Reply With Quote
Old 10-03-2014, 10:40 AM   #2
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
Yes and yes. I put the precision temp marine version in my previous trailer and apart from the extra cost it's all win win.
truckasaurus is offline   Reply With Quote
Old 10-03-2014, 12:19 PM   #3
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Precision Temp 500. Pricey, but wonderful!
Old 04-30-2015, 05:44 AM   #4
1989 35' Argosy 5th Wheel
1979 rgosy 27
Danville , Vermont
I am using the unit that fits into the location of the atwood tank heater. Purchased from PPL RV. This unit also has external flange and door that is customized to replace the original heater for original look. I like it but have had two issues. I had the single mixing valve in shower, and this does not always allow the proper flow to keep the heater on. I had to change that to a separate cold and hot water fixture. Second, I am now exploring if the gas supply needs modification. It is at the end of the gas line with 3/8ths tubing. I suspect it is not getting full 11"wc so it has had it's moments of intermittant heating. I am still glad I switched for weight and LP efficiency. Did not know about precision temp marine unit.
fordfarmer is offline   Reply With Quote
Old 04-30-2015, 12:18 PM   #5
2007 22' International CCD
We use a precision temp 550. No change to propane piping needed. Was able to relocate line to fit new HW heater. Only issue I've had was running low on propane or low water flow due to a crap external regulator.
rmkrum is online now   Reply With Quote
Report on Marey On Demand Tankless Hot Water Heater Collapso LP Gas, Piping, Tanks & Regulators 5 12-08-2012 05:44 PM
Atwood on-demand water heater svanpelt Plumbing - Systems & Fixtures 1 11-28-2012 10:34 PM
On Demand Water Heater? codybear Water Heaters, Filters & Pumps 4 06-04-2011 10:27 AM
Small Electric on-demand water heater and a 20A plug Globie64 Electrical - Systems, Generators, Batteries & Solar 5 04-14-2011 07:49 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
