Old 07-15-2015, 03:12 PM   #1
new and loving it!
1978 28' Ambassador
sycamore , Illinois
Not the smartest!
Hi
SO my handy friend and I bought a 1974 29 foot airstream that someone gutted and re-insulated and paneled. Actually more than that. The problem...No bathroom it was all taken out but nothing put back in but a mounted toilet. Here is my question, sorry to be long winded We were told it needs a split tank gray and black. Would it be better for us to take it to an Rv service center to have this done or is it something we can do ourselves? The freshwater tank is fine.
Thank you
I don't know what we were thinking buying this
gina529 is offline   Reply With Quote
Old 07-15-2015, 03:19 PM   #2
carver 1's Avatar
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo , Florida
Images: 30
Gina,
In the absence of the black water holding tank you might want to consider a composting toilet. Check out airhead.com
>>ron<<
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
carver 1 is offline   Reply With Quote
Old 07-15-2015, 03:38 PM   #3
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Or a cassette toilet as used in European campers. I have a Thetford C403 in my Argosy MH.
martin300662 is online now   Reply With Quote
Old 07-15-2015, 04:02 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you believe in your use of the word handy there is no reason you could not do it yourself. You are only talking about measuring and cutting plastic pipe and mounting the tank or tanks. Odds are you will do a better job.
I would suggest you install both a gray and black tank if you intend to use the trailer beyond campgrounds with sewer.
2004 Excursion 4x4
Old 07-16-2015, 07:19 AM   #5
new and loving it!
1978 28' Ambassador
sycamore , Illinois
Thank you all!! We have looked into a composting toilet, now the handy man thinks he can install either tanks or a composting toilet. So this is going to be interesting. With these ideas he now feels he can move the bathroom to the center instead of keeping it in the rear!
Help! Battery not charging, outlets not working when plugged in AirGal04 Electrical - Systems, Generators, Batteries & Solar 9 06-06-2014 09:15 PM
