Old 10-16-2019, 01:38 PM   #1
2015 23' FB Flying Cloud
Amelia Island , Florida
Not getting LP to appliances.
Problem with our 2015, 23FB Flying Cloud. We left home this morning and at our lunch stop noticed the “check” light was on and the refrigerator will not light. Tried lighting the stove and it is not getting LP. Tanks are full and the regulator is 1 year old. Any ideas? Blockage, where? Ideas?
Bigreptile is offline   Reply With Quote
Old 10-16-2019, 01:53 PM   #2
DougFelts's Avatar
2019 26' Flying Cloud
Poulsbo , Washington
We've learned a little about this...
There is a function of the valve on the tank so that flow is markedly reduced if there is a damaged line. So, first step would be to check the lines under the front of the trailer to see if there is any obvious damage. Then, close the valves, purge the line by opening a burner on the stove, and then SLOWLY reopen the valve on the tank.
This MIGHT work. Didn't work for us, but it's worth a try!
We ended up having to adjust the regulator.
Let us know what you learn!
DougFelts is offline   Reply With Quote
Old 10-16-2019, 02:16 PM   #3
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Pigtail check valve shot
2 stage regulator shot
Low point at flex line under regulator full of oil
Flex line between regulator and copper line delaminated
Opened valve too quickly and opd blocked flow
AtomicNo13 is online now   Reply With Quote
Getting ready to travel back to the dealership to pick up our 2019Nest 16U. Getting m RichAnthony Nest 2018 - 2020 1 06-11-2019 01:45 PM
Propane Not Reaching Appliances 3bcamper Sprinter and B-van Forum 15 05-02-2017 04:45 PM
Propane appliances not working dkrukosky LP Gas, Piping, Tanks & Regulators 10 08-01-2013 07:06 AM
Fridge not getting cold enough Dbartmann Refrigerators 7 06-13-2006 05:36 PM
getting there but not happy with finish??? Ed Starman Cleaning, Stripping & Polishing 10 05-11-2005 08:00 AM
