Old 08-16-2019, 06:53 PM   #1
tkowalyk's Avatar
2013 27' FB Classic
North Wales , Pennsylvania
Images: 11
No power to propane detector
Looking for some help.
I have a 2013 27 Classic and I donít have any power to the propane detector.
Iíve checked the fuses and they are all ok. Iíve looked underneath the closet and can trace the wires until they go into a large bunch of wires and there is no inline fuse.
The propane detector is not connected to the disconnect.
Thanks!
Tom & Lori
2013 27 FB Classic Limited
2016 Nissan XD Turbo Diesel
WBCCI 03288 TAC PA-17
tkowalyk is offline   Reply With Quote
Old 08-16-2019, 07:12 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
On some Classic's the power for the propane detector comes through a fuse to the power bus at the front of the trailer. It's located under the "sofa" (or whatever you have) at the front of the trailer.
No matter what, it's a very simple circuit. A fuse goes to the battery bus (ahead of the use/store relay) and the output of that fuse goes to the detector. It's the only thing on the circuit.
Indeed if your trailer has been modified in this or that way after it left the factory .... all bets are off.
Old 08-16-2019, 08:03 PM   #3
tkowalyk's Avatar
2013 27' FB Classic
Images: 11
Thanks Bob - I have twins up front and I know where the relay is.
Iíll check there first thing in the morning.
Thanks again!
Tom & Lori
Old 08-17-2019, 11:39 AM   #4
tkowalyk's Avatar
2013 27' FB Classic
Images: 11
Uncle Bob - your advise was perfect.
I replaced the fuse and I have power!
I replaced the propane detector, and installed a push button disconnect just below the detector. Interesting enough, with the switch off (I have it connected to the common or ground) itís registering .4v; Iíve got 12.9 when the switch is on.
Thanks again!
[ATTACH]349679
Tom & Lori
Old 08-17-2019, 11:42 AM   #5
tkowalyk's Avatar
2013 27' FB Classic
Images: 11
Finished
Tom & Lori
Old 08-17-2019, 11:44 AM   #6
SilverWind's Avatar
2017 25' International
1968 17' Caravel
Los Osos , California
The propane detector is intended to be powered full time as a safety measure. Disconnecting it could compromise occupants well being. I would not want to purchase a used Airstream that has a bypass.
SilverWind is offline   Reply With Quote
Old 08-17-2019, 02:07 PM   #7
tkowalyk's Avatar
2013 27' FB Classic
Images: 11
Silverwind - only bypassing it for long term storage. Itís a simple on / off switch.
We used our lable maker to put a note on the mirror as a reminder to turn it on
Really - you wouldnít buy an Airstream because of the option to disconnect the monitor from the battery?
[ATTACH]349697
Tom & Lori
Old 08-17-2019, 03:36 PM   #8
SilverWind's Avatar
1968 17' Caravel
[ATTACH]349697
I would remove the disconnect switch. Too easy for kids, dog, shoes etc to press the button and disable the detector.
Old 08-18-2019, 06:30 AM   #9
tkowalyk's Avatar
2013 27' FB Classic
Images: 11
Tom & Lori
Old 08-18-2019, 07:30 AM   #10
2007 22' International CCD
My long term storage solution for vampire loads like the propane detector is outdoor storage and 150 watts (soon to be upgraded) of solar to keep the batteries charged.
This lets me run at least one Fantastic fan to vent out some heat when itís hot out as well.
Old 08-18-2019, 07:30 AM   #11
Half a Rivet Short
Hi
The other gotcha with a detector disconnect - it may not be the biggest parasitic drain you have on your trailer. On many trailers it's actually a pretty small part of the drain.
Old 08-18-2019, 08:58 AM   #12
Mollysdad's Avatar
By law a propane detector may not have a switch installed by the manufacturer.
IMO, the solution to parasitic loads is a battery disconnect at the batteries.
Old 08-18-2019, 12:58 PM   #13
Annapolis , Maryland
Dog and propane detector
To further Silver Wind, one of our dogs loves to lounge by the propane detector. At times, the alarm will sound, followed by aSBD. Then the dog jumps. Not sure if the SBD is a cause or a consequence, but funny nonetheless. Most likely, the dog is leaning on the test button. So a shut off would only likely be tripped on a regular basis.
rhpeahl is offline   Reply With Quote
Old 09-10-2019, 09:35 PM   #14
doughpat's Avatar
2019 22' Sport
Bend , Oregon
Wowó150 watts just for parasitic drains? Is that overkill or are you in a shady place? I was hoping 80watts would give me a (small) surplus (in full sun).
doughpat is offline   Reply With Quote
No power to propane detector kebrita LP Gas, Piping, Tanks & Regulators 3 08-01-2019 08:32 PM
Propane Gas Detector Went off Last Week-Turns Out NOT the Propane breezyway Electrical - Systems, Generators, Batteries & Solar 4 08-16-2014 08:56 AM
Propane Gas Alarm/Detector Wiring campadk Electrical - Systems, Generators, Batteries & Solar 4 05-02-2007 06:16 PM
Propane Detector Jim Tyrney Airstream Motorhome Forums 10 08-02-2005 08:55 AM
