Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 12-18-2015, 09:48 AM   #1
2015 27' FB International
Chapel Hill , North Carolina
No LPG getting through
I have a 2015 International 27FB, which I bought new a little over a year ago now. Suddenly, I have no LPG available for anything (stove, furnace, fridge). I have a full LP tank, the Cavagna (switchover) regulator shows green. Could my regulator be defective? I'm currently parked in Oceanside CA so not subfreezing. Am I missing something? BTW - on a couple other occasions in the past few months we noticed that the stove was getting no gas for awhile, but suddenly started working normally again. At the time I just thought there was a hiccup in the system somewhere and quickly forgot about it... until now...
RichardW is offline   Reply With Quote
Old 12-18-2015, 09:53 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
First thought, are the valves on both tanks open fully?
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 12-18-2015, 09:54 AM   #3
Sag Harbor , New York
The newer regulators can do this, if they have sensed a possible leak in the lines. Turn off both tanks completely, turn off water heater and fridge propane options, and then turn on the active propane tank by opening its valve VERY slowly. Try lighting one burner on the stove top. Burner lights OK?
Old 12-18-2015, 10:04 AM   #4
The valve is open on one tank (the other tank is empty). I'll try closing things off as suggested and see what happens. (Although I did try a similar process earlier... may not have opened the tank valve slowly though.) Thanks!
Old 12-18-2015, 10:40 AM   #5
Ok, I went through the process that OTRA15 suggested and the stove burner lit with a low flame for about 5 seconds, then went out. Tried the process again (along with unhooking the pigtail connector) and the burner won't light at all.
One thing that I didn't mention earlier was that about a week ago I noticed a pinhole leak on one of my pigtail hoses. I therefore shut that pigtail side off and have only been using the LP tank on the other side since then. (I have not had time to replace the bad pigtail yet.) Everything was working fine on the good side until yesterday. Interestingly, even when I had the pinhole leak in the pigtail, the regulator was still allowing gas to get through.
Old 12-18-2015, 10:55 AM   #6
kdickinson's Avatar
Taos , New Mexico
regulator or tank switch probably. Or an empty bottle. If your bottles are going down faster than normal you may have a leak
kdickinson is offline   Reply With Quote
Old 12-18-2015, 10:59 AM   #7
2016 30' Flying Cloud
Oviedo , Florida
1) leak large enough to trip the regulator or POL connector on the pigtail into bypass mode
2) bad regulator/changeover valve
3) bad pigtail (POL going into bypass incorrectly)
You need to start substituting some parts to find the problem (you need a known good pigtail and regulator)
I guess the OPD valve in the cylinder could be bad as well, although I'm not sure exactly what the failure mode is there
Keith & Barb
2016 Ram 2500 diesel
Southeastern Camping Unit, WBCCI #1675
khollister is offline   Reply With Quote
Old 12-18-2015, 11:11 AM   #8
Thanks for the feedback. I bought 2 new pigtail connectors. Will test them out later today.
Old 12-18-2015, 11:29 AM   #9
Oviedo , Florida
You may be about to find out that Airstream uses 1/4" NPT connections between the regulator and pigtail. Industry standard (especially in the retail chain for parts) is 1/4" inverse flare. You may need to add or remove adapters.
Keith
Keith & Barb
Old 12-18-2015, 01:58 PM   #10
Keith
New correct pigtails should reduce the variables at least, and hopefully prove the solution.
Good luck!
Peter
Old 12-18-2015, 03:05 PM   #11
Mission , Texas
It may take more than one time turning the gas on.
The leak protection shuts down the flow to nothing or almost nothing. So if the gas lines aren't already pressurized, when you open the tank valve, it thinks there is a leak it will shut itself down.
nrgtrakr is offline   Reply With Quote
Old 12-18-2015, 03:39 PM   #12
1973 31' Sovereign
Middletown , California
I sometimes have to move the manual change over valve to the new tank side and also open the valve very slowly to get gas to flow. There seems to be some kind of shutoff valve inside the regulator that this re-sets after running both tanks empty. I didn't have to do this on my old regulator. I haven't gotten more than a year or two out of inlet hoses before they harden up and leak around the crimp fittings, I'm hoping to find some that last better someday. I'm almost ready to go back to copper inlet lines due to these leaks. I hope the new lines fix the problem. Leland
ijustlee is offline   Reply With Quote
Old 12-18-2015, 04:33 PM   #13
Ok. As Keith eluded to, I wasn't able connect my new pigtails directly to the old regulator. I swung by the Airstream dealer in San Diego and picked up a new regulator. The tech there also thought the problem was in the regulator as well. I installed the new regulator and pigtails and everything is lovely now!
This should have been a warranty repair as my AS is only about a year old. The dealer here was booked until January, so no way I was going to wait for that. They were very helpful in any case when I explained the situation and bought a new regulator. It was relatively easy to fix... just a bit aggravating that it malfunctioned already.
Old 12-18-2015, 04:36 PM   #14
Thanks to all for the advice!
Old 12-18-2015, 05:08 PM   #15
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Just so that I know in the future, if this kind of thing happens to me. Isn't there a way to get reimbursed for what should be covered under warranty?
SeaLevel is offline   Reply With Quote
Old 12-18-2015, 05:31 PM   #16
Thanks for the update, you are a long way from home! At least you are on the road again.
Old 12-18-2015, 06:08 PM   #17
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Haines , Oregon
Save your receipt. Send a note to Airstream and your dealer to explain the situation, and ask to be reimbursed.
Old 12-19-2015, 05:52 AM   #18
Curious where you are headed next? In the 90's we took a major road trip from NY to San Diego and Napa, through Texas both ways because it was winter, and had a blast. Two months in all.
If you feel like it, maybe a new post on the forum "On The Road" would be interesting? The threads there usually have great campground and restaurant tips from fellow travelers both past and present.
On The Road... - Airstream Forums
Any suggestions for good music that makes you want to get On The Road Again when you hear it?
http://www.airforums.com/forums/f161...-i-143331.html
Have a great trip!
Peter
PS -- It is likely that your warranty will cover at least the parts you had to buy, if you can explain your diagnostic process and provide the comments of any Airstream parts/service people who agreed with you.
Old 12-19-2015, 10:06 AM   #19
Peter - Thanks for the feedback and links. This thread made me realize that I hadn't (ever) updated my profile. We've spent the past year upgrading/modifying a number of aspects of our rig (solar, electrical, tech, etc.). We also sold our house in Chapel Hill in July and have been full-timing it ever since. So, after the last 25 years in NC, I'm not sure what I should call home right now! We spent late summer/early fall in Ontario, north of Toronto then down to southern Florida. We then took the southern route to CA, mainly I-10. We took a detour into Big Bend National Park. Also drove up FM170 along the Rio Grande. That was absolutely beautiful. We will definitely go back to Big Bend again someday. We're currently parked in Oceanside, CA at the moment (I consult for a couple companies in the area). We plan on staying around here until spring (with a number of CA excursions in between - suggestions?). This summer we'll be heading north again into Canada. Not exactly sure where yet, there's so much up there to see too.
I always start singing "On the road again" as we're hitching up, preparing to head out (probably to the annoyance of my wife)...
Old 12-19-2015, 10:30 AM   #20
Got me laughin' there, Richard -- I do the same thing with that song . . .
You might check out the 20-footer thread, as a few posters there have recently recommended campgrounds very close to you.
Start here maybe and check out the more recent posts:
http://www.airforums.com/forums/f516...ml#post1689725
In between the posts about windows, plumbing, winterization etc. -- some of them a bit verbose [guilty as charged] -- are some good photos and ideas about Southern California campgrounds, mostly from subfan1. And Bob and Myrna [CruzinDux] from Eugene OR are going to be heading that way after New Years probably.
I went to UCSD and lived in North San Diego County back in the 70's, so I am enjoying hearing about the area again, as well as your journey getting there!
Happy Trails . . .
Peter aka OTRA15 -- On The Road Again!
Nothing getting through the Pilot jet wander'n Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-29-2009 10:20 PM
Horizontal LPG Bottles on "Limited" models Dwight LP Gas, Piping, Tanks & Regulators 15 05-31-2005 07:18 PM
Fix or replace LPG regulator? Roundhead LP Gas, Piping, Tanks & Regulators 26 03-27-2004 03:28 AM
What you wanted to know about LPG and more femuse LP Gas, Piping, Tanks & Regulators 0 04-24-2003 10:12 AM
LPG or propane in the bottles ? brunoffrance LP Gas, Piping, Tanks & Regulators 3 12-17-2002 03:18 PM
