Old 06-20-2008, 05:59 AM   #1
gowyn's Avatar
2007 27' Safari FB SE
London , ontario
No Gas
On the road so not sure when I can check this but here goes.
07 27FBSE.
One 30# was empty so had it filled. Switched reg over to other tank. Everything ran fine until it was empty.
So I switch over to the recently filled tank but no gas. So then I switched the two tanks putting the filled one on the gas line that the empty one was on. Gas.
So I doubt the line from the tank to the reg is blocked (tank only off for an hour) so wondering what folks thoughts are?
So today I'll get the empty filled and try again.
gowyn is offline   Reply With Quote
Old 06-20-2008, 06:17 AM   #2
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Some regulator and OPD valve combinations aren't the best of friends. Try this:
1. Close the full cylinder via the triangular turn handle on the top.
2. Turn the regulator away from the full cylinder. (These first two steps are just to get you back to the starting point.)
3. Turn the regulator back to the full cylinder. Your indicator on the regulator should be reading red at this point.
4. Now the important part: VERY slowly open the valve on the top of the propane cylinder. Turn just a tiny bit at a time until open. You should see the regulator indicator switch to green; you may also be able to hear a swish noise as it happens.
If the regulator goes to green, then this was likely the problem. If not, the problem lies elsewhere.
Oh, just in case, you note that you're getting alternately "no gas" and "gas." How are you making that determination?
Lynn
WBCCI 21043
Old 06-21-2008, 01:22 PM   #3
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
usually it`s that you didn`t have hose completely tight,I`ve ran into this on my grill. Dave
easyride is offline   Reply With Quote
Old 06-21-2008, 01:28 PM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
Good answers so far. If your regulator doesn't have an indicator (the OEM on my 06 FB SE doesn't), the best way to check gas and run a volume back from the tank at the same time is to use the stove burners. Use a match and not the igniter. Open a stove valve and check over a period of time whether gas has arrived. Then operate what other gas using appliances you're trying to run; eg, fridge, HW heater, furnace -- don't have to do them all immediately though. Please let us know how this turns out.
5 meter Langford Nahanni
Old 07-01-2008, 08:14 AM   #5
gowyn's Avatar
London , ontario
well got back home and tried it again. Worked fine this time so I guess it was just too much pressure too quickly on the OPD valve opening.
Thanks all.
Old 07-01-2008, 09:16 AM   #6
SilverCottage's Avatar
LONDON , ON
I had the same problem last year. I figured the tank was empty and the guy said it was full when he went to fill it.
Items #2 and #3 here explain the testing and operation of the auto changeover valve.
5th Wheel Remote Cylinder
SilverCottage is offline   Reply With Quote
Old 07-01-2008, 09:19 AM   #7
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
I also had this happen to me once... the propane guy I talked to flipped the tank over (closed) and tapped the tank on the ground (softly). He said the opd's sometimes get stuck.... worked like a charm.
Marc
Locking Gas Cap for 2003 AS Gas Motorhome spat61 Land Yacht/Legacy Motorhomes 11 10-27-2008 11:37 AM
LP Gas Detector - 2005 Classic Stream 1529 2001 - 2005 Classic 2 06-15-2006 06:44 AM
Gas..... canny_banjo_man Off Topic Forum 3 02-08-2005 09:50 PM
A little gas to get to WA! fabofabo Our Community 0 11-08-2004 07:41 PM
What a GAS... canny_banjo_man Off Topic Forum 1 09-14-2004 12:16 PM
