Old 10-31-2015, 06:07 PM   #1
1989 32' Excella
Sharon Springs , New York
Newtec Gas Detector replacement question
Have a 1989 Excella with a Newtec Gas Detection Unit's alarm that won't shut off unless I turn the switch off. Will that affect the LP gas flow to the furnace, water heater or fridge? The stove works ok but I haven't tried the other stuff on lp as its winterized now. I know I need to replace the detector anyway, will it matter which brand I use because Newtec is out of business I believe. The unit is a 2-wire, flush-mount, 12 volt set-up and looks pretty standard. My lp tanks have wires coming off
them, but I think they are for the fuel level monitoring system, could be wrong though. Any experience with replacing the gas detector would be appreciated.
Regards,
James
Easyrider06 is offline   Reply With Quote
Old 10-31-2015, 10:00 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Does the detector have an LP connection????
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-01-2015, 01:25 AM   #3
1989 32' Excella
No, it doesn't, just the 2-12v wires (1-black/1-red)...
Regards,
James
Old 11-01-2015, 10:37 AM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I didn't think so.. Sounds like you need a "replacement" detector. That is usually how they "fail"..
Channing
WBCCI# 30676
Newtec Gas Detection Control Unit? FarmRVMan LP Gas, Piping, Tanks & Regulators 2 05-02-2010 10:21 PM
Gas & Pollution Detector? 66Overlander 1984 - 1989 Sovereign 6 02-16-2009 07:13 AM
LP gas detector uucal LP Gas, Piping, Tanks & Regulators 0 03-07-2004 08:39 PM
Engine will not start - LP Gas detector? AccessMaster Airstream Motorhome Forums 6 08-31-2003 08:38 AM
Gas Detector winner Airstream Motorhome Forums 2 07-02-2002 03:59 PM
