Having problem with Newtec gas Detection Control Unit. When I turn unit on I still dont get switch at propane tanks to open and allow gas flow. When I hit the reset button on the unit the alarm immediately sounds and I get gas to stove but not enough pressure to hot water heater to give me all but a small burn and the alarm wont shut off until I turn the unit off which then cuts flow of gas. Battery is fully charged and I am plugged into AC outlet. Do I have a bad gas detection unit? I understand Newtec went belly up? Replacement manufacturer if this is my problem?
