Old 04-01-2014, 10:09 AM   #1
1965 17' Caravel
Marshall , North Carolina
Newbie wondering if she can hook up a regular propane tank!
Howdy!
I'm living in a friend's old Caravel in its permanent home on her farm. I'd like to cook on the stove, but the airstream doesn't have propane tanks. I know it's probably not ideal, but I'm wondering if I can hook up a regular old propane tank to the airstream hookup so I can use the stove?
Also, in case this is relevant info, I'm not actually sure of its year.
Thank you!
A.
ASauser is offline   Reply With Quote
Old 04-01-2014, 10:17 AM   #2
1976 31' Sovereign
Oswego , Illinois
Smile propane hook up
Originally Posted by ASauser View Post
Howdy!
Thank you!
A.
Yes you can hook up 100 lb. propane tanks to AS but must use AS regulator if old pur. new as old may not be safe. Bill
Old 04-01-2014, 10:20 AM   #3
1987 25' Sovereign
Oregon , Ohio
A tank like from a gas grill or another travel trailer should work fine. You may have to get some fittings to hook it up. Do you have a friend that is a plumber? Propane and natural gas are not to be played with. They can be dangerous if not handled properly.
msmcv51 is offline   Reply With Quote
Old 04-01-2014, 10:20 AM   #4
damonbeals's Avatar
1998 31' Excella 1000
1979 23' Safari
Mooresville , Indiana
Yes if the connections are still there and the hoses are not rotten, you can go buy a gas grill propane tank and use it. There is nothing special about the tanks. But if the system has not been used in years, you should do a leak test, because you don't want a leak.
Damon
#4827
damonbeals is offline   Reply With Quote
Old 04-01-2014, 12:41 PM   #5
SStar's Avatar
2004 28' Classic
Midland , Texas
propane hookup
If it is an older trailer it probably will have the old style fittings. If so that fitting (left hand thread) will screw into a 100# bottle. ( you still need a regulator) The newer travel trailer / propane grills with small bottles were changed a few years back. Can you take a photo of the fitting and regulator if it is on the trailer and post it? It is easy to see the difference.
SStar is offline   Reply With Quote
Old 04-01-2014, 02:06 PM   #6
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Won't the old grill fittings (left hand inside thread) still screw in to the inside of the new tanks, but new fittings (right hand outside thread) won't screw on to the old tanks?
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 04-01-2014, 08:44 PM   #7
SStar's Avatar
2004 28' Classic
Midland , Texas
Al
You are absolutely correct! I attached a couple of photos for clarification.
Name:	April First 059.jpg
ID:	208789   Click image for larger version
Name:	April First 060.jpg
Wondering what I can sell it for 99Limited34 Trailer Values 24 03-14-2010 07:52 PM
Hook up OR Not Hook up while camping purman Boondocking 29 08-18-2009 06:42 PM
Can you hook up a disposable propane cylinder? bhayden LP Gas, Piping, Tanks & Regulators 5 06-16-2006 09:10 PM
She's no Zip Dee - but she'll do..... GT1963 Awnings 3 05-12-2004 03:43 PM
Can I use "regular" antifreeze in my holding tank? Luckydog Airstream Motorhome Forums 6 11-25-2002 07:01 AM
