Old 08-18-2014, 09:49 PM   #1
Larkspur , California
Newbie question re. refill of propane tank
Must the tanks be removed from trailer to refill? Seems I could save a lot of trouble by leaving tanks in place and pulling up to refill station?..Please advise..Thanks!
Johnny P
wbcci #27309
jpfromla is offline   Reply With Quote
Old 08-18-2014, 09:51 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Depends on the refill station. I have had my tanks refilled on the trailer and off. Not really a hassle to take them off, then you don't have to pull the trailer to the propane dealer. Depending on where you have them filled, ther may not be room for a truck and trailer.
Bill
Johnny P
wbcci #27309
Just my personal opinion
Old 08-18-2014, 09:53 PM   #3
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
It has been my experience that they will ask you to take them off as they weight the tanks as they fill them as it tells them how much they are putting in.
Hope this helped
Cheers
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 08-18-2014, 09:57 PM   #4
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Some stations fill without scales. The bleed until liquid propane comes out the bleed hole and then stop filling.
Old 08-18-2014, 10:40 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I would rather have the tanks off... that way I do not have to concern myself as much with potential damage done by refill operator..
Should a valve malfunction, I would rather my AS not be anywhere around it..
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-18-2014, 11:09 PM   #6
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Ditto that! Each year before the start of our fall camping season, one of my two propane tanks is empty and I remove it and place it in our truck, along with any other smaller propane tanks used for cooking, and haul them to our favorite U-Haul dealership for refilling. I would never want to pull our trailer into a lot for refilling propane tanks.
I have the same feeling about gas stations. Fortunately, we are content in camping in San Diego County, where we have beach, mountain and desert camping options year round. So I refill the truck's diesel tank prior to each trip and have only had to stop once while hauling a trailer at a gas station in the past 8 seasons of camping.
SilverGate is offline   Reply With Quote
Old 08-19-2014, 08:20 AM   #7
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
True, but then they charge you for a full tank even though it may have been half full.
Ahab is offline   Reply With Quote
Old 08-19-2014, 09:28 AM   #8
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Pay by weight or volume?
The most convenient fueling - at my home campground:
  • remove the tank(s) and place them in front of the trailer
  • go to the office and get a tag/authorize credit card use
  • go shopping, take a nap, enjoy life as usual
  • If I'm at the trailer when the filled tanks are delivered the work camper usually offers to mount them for me, if not I put full tanks back on the airstream/grill/etc.
They don't use a scale but do charge by volume (cubic foot I believe) so it's quite convenient to have even partly empty tanks filled prior to taking a trip.
Paula
Old 08-19-2014, 09:43 AM   #9
2016 30' Classic
Erie , Colorado
If your propane refiller is still using the screwdriver/bleed valve method on newer tanks they haven't been properly trained. All newer tanks, the ones with the three sided knob, are auto shutoff when full. This OPD (Overfill Protection Device) valve was made a law in 2002 for all tanks 40lb down to 4lb.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 08-19-2014, 10:53 AM   #10
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
If you have a built-in ASME tank, such as on an Airstream Interstate, that's the only way.
They should be metering the flow rate, and charging you by the gallon. Again, that's what they do with ASME tanks. If they're not filling by weight and not charging by the gallon either, then report them to whichever state agency licenses propane dispensers in your state, because they're in voilation of state regulations and could lose their license to sell propane.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-19-2014, 02:10 PM   #11
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Ah, not quite. The OPD valves are to prevent home-fillers from overfilling a cylinder. However, if you look at the big book on propane (NFPA 58) that states use to set up their laws, you'll discover that professional fillers are not supposed to be relying on OPD valves as a means to determine full. And for good reason: Unlike professional filling stations, which are inspected, an OPD valve is never inspected again after original installation.
Lynn
WBCCI 21043
Old 08-19-2014, 07:43 PM   #12
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We have only had to pay for propane on a flat rate for the tank once ... in a mountain town in NM. We usually buy our propane at home ... it is metered and charged by the gallon, which I prefer. Then I know I am paying for what I am actually getting.
TB & Greg and Abbey Schnauzer
#3954
Old 08-19-2014, 08:08 PM   #13
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Yep, I think I got rooked by that once, too. Paid 30 bucks for my stupidity for not asking first. Oh, well, if that was my last error in judgment, then I sure don't have much longer to live.
Lynn
WBCCI 21043
Portable Water Tank Refill Product DreamsInSlvr On The Road... 7 01-12-2014 03:04 PM
Propane Refill on I-65 Alabama? Ridgerunner3 On The Road... 4 01-01-2012 08:49 PM
Refill bottles ? brunoffrance Our Community 16 03-14-2004 11:10 AM
Bleed lines after propane refill!!! Astrodokk On The Road... 4 12-01-2003 11:08 PM
Propane refill question Kistler LP Gas, Piping, Tanks & Regulators 2 10-19-2003 07:39 PM
