Old 01-24-2013, 11:12 PM   #15
1963 28' Ambassador
Foley , Alabama
Yep, now that my baby is here, they are old old propane tanks. I've decided to get 2 new 30lb aluminum tanks. Open for suggestions about where to buy them. I saw them on the vintage airstream site? Has anyone purchased them there?
tredding is offline   Reply With Quote
Old 01-25-2013, 06:59 AM   #16
1982 34' Limited
Harrowsmith , Ontario
Vintage Trailer Supply has them: Vertical Aluminum Propane Tanks
You might try Worthington directly to see if they have someone local you could get them from - shipping might be cheaper. On the other hand VTS has free shipping until the end of January!
BradB is offline   Reply With Quote
Old 01-25-2013, 07:01 AM   #17
1984 31' Sovereign
charleton , Illinois
If you buy used make sure they have the new style valves or you will not be able to have them filled.
jerry d is offline   Reply With Quote
Old 01-25-2013, 07:06 AM   #18
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
If those original cylinders are aluminum, and they are in decent shape, I wouldn't bother getting new cylinders. Recertify, refit with OPD valves, fill them up, and use them!
Lynn
WBCCI 21043
Old 01-25-2013, 08:26 AM   #19
1982 34' Limited
I had new valves put on my aluminum tanks last summer, it wasn't too expensive - far cheaper than new tanks.
I'm guessing from the rust that those are steel though.
