03-20-2012, 06:58 PM
1980 25' International
Avon
, Maine
new water heater?
Hi, First time here, first airstream. In the midst of renovating, don't want to wait for the Atwood tankless water heater. Rather upgrade than put in another tank heater. The RV 500 is slightly larger, has anybody put one in, I'm replacing a Bowen (Atwood now?) 6 gallon. Do I need to cut out on the outside of trailer or just modify inside space. Loath to cut away skin, inside not a problem. Ordering new furnace too. Thanks
03-20-2012, 07:18 PM
1974 Argosy 26
Morrill
, Nebraska
If you had a 6 gallon Bowen as original equipment, the 6 gallon Atwood will slip right in. Mine did. I even used the original cover or door.
03-21-2012, 10:21 AM
Jonesboro
, Georgia
03-22-2012, 10:51 AM
Avon
, Maine
Kristi, did he replace it with a RV 500 tankless heater or another tank heater?
I don't want to have to modify the outside of trailer, inside not a problem. I may just get an Atwood 6 gallon and wait a while to upgrade to a tankless Atwood after they get the bugs out. thanks
03-22-2012, 12:27 PM
1968 24' Tradewind
Oxford,
, Mississippi
Your are correct , you don't want to change the outside if you don't have to. I had to do some modes to the outside on my 68 when I installed a new Atwood (old heater was bigger than the new ones). I would suggest you get the DSI model 120/propane version. They cost more but to be well worth the difference in price. Being able to just flip a switch to light the heater is worth the extra money. If you need hot water fast when you get to a full service camp site you can use the electric and gas at the same time. When the water is hot, just flip the gas switch off and the heater will use only electricity, saves your propane. IF you need a quick recovery after a shower then just flip the gas switch and you get really fast heating.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
03-23-2012, 02:39 PM
Jonesboro
, Georgia
He replaced the old 6 Gallon Bowen hot water tank with a new 6 Gallon Atwood tank. He saved the housing from the original hot water tank, and with a few adjustments, was able to put the Atwood tank into the Bowen housing allowing for the original outer access door to still fit.
03-23-2012, 03:22 PM
1972 25' Tradewind
North Vancouver
, British Columbia
If you send a private message to Lewster, who is a commercial member here, he'll be able to tell if the RV500 is a straight fit or not. He's installed them and has first hand knowledge about the unit in question.
North Vancouver, BC
03-23-2012, 04:09 PM
Avon
, Maine
Awesome, thanks for the info everyone. Going with electric/gas Atwood for now, will upgrade to tankless later, capable of cutting skin but a bit of a purist. Restoration coming along well.
04-01-2012, 10:44 PM
2020 30' Classic
Derwood
, Maryland
Originally Posted by Kristi Foster
He replaced the old 6 Gallon Bowen hot water tank with a new 6 Gallon Atwood tank. He saved the housing from the original hot water tank.
Now that's some great thinking & an awesome tip!
John "JFScheck" Scheck
2020 30’ Airstream Classic
**I Love U.S.A.**
04-01-2012, 10:59 PM
1974 Argosy 26
Morrill
, Nebraska
The Atwood that I installed has a styrofoam cover. It fit right in where the old Bowen unit was. Did not use any part of the old Bowen for the new installation.
04-04-2012, 07:13 AM
2020 30' Classic
Derwood
, Maryland
My water heater on both the 2009 & 2011 utilize styrofoam as the outside so might be easier to install other heaters and still utilize the thermal cover...
**I Love U.S.A.**
