Old 08-12-2016, 12:16 AM   #1
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
New tanks, or re-certify?
Hi, right now I have two relatively full propane tanks. But they are now dated as over 12 years old. Legally, it is not legal to refill these tanks unless replaced or re-certified. Re-certifying these tanks are for 5 years, and then what? Five more?
I checked the dates; My trailer was built in 2004. One tank is dated 2004 and the other one is dated in 2003. About six months older. I would have expected both propane tanks to have the same date. I never paid any attention to these tanks dates until now.
If this situation has been posted before, I missed it.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-12-2016, 12:44 AM   #2
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I'm guessing it's a matter of doing the math and then factoring that by how long you expect to be using those tanks. The math is pretty universal, the other part is strictly personal.
What is rediculous about this new procedure/law is how simple the test is and how much some are charging to perform it.
Ken
Old 08-12-2016, 01:20 AM   #3
Salem , Oregon
Images: 18
Hi, I just done some more searching a read some interesting stories. In Canada propane tanks are good for 10 years and they don't recognize the US 5 year re-certification. Prices to certify are all over the place. Some places inspect for leaks and physical condition. And some places want the tanks to be empty, or they will burn off what is in the tank.
Note: this is some of what I read, but not necessarily true facts.
2005 Safari 25-B
Old 08-12-2016, 03:58 AM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
If they are the aluminum tanks it is usually well worth having them recertified, aluminum tanks are expensive to replace. I had mine recertified for free, had the place that fills our company fork lift tanks do it as a courtesy. If you have steel tanks it is probably a wash in terms of cost.
Aaron
WBCCI #XXXX AIR #2495
Old 08-12-2016, 04:24 AM   #5
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Bob,
What do they actually do to re-certify?
I noticed one valve was broken last Spring, so I replaced both, soap test, checked for corrosion,(aluminum), purged & filled at CW and used my "certify" kit.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 08-12-2016, 04:39 AM   #6
2000 30' Excella
Toledo , Ohio
my last Airstream was a 1985 and the tanks were dated 1973 other than putting in new OPD valves they were in great shape and had them re certified .
woodfox45 is offline   Reply With Quote
Old 08-12-2016, 05:14 AM   #7
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Each state in the US can have their own re-certification laws, but they have to meet the minimum set by the US government. https://www.google.com/url?sa=t&rct=...,d.eWE&cad=rja
Where I live in both NC and FL, there is a certification type that is called "visual". The vendor installs a stick on label that identifies them and states the type of inspection. This type of test has to be done every 5 years once the bottle is re-certified. I've had some vendors do this test for free when I fill up at the same time. Other vendors have charged ~$10-$12.
There is second type of test, not sure exactly what they call it, but the bottle is pressurize so that they can test for leaks and function of the safety devices. I've never seen this test and I do not know how the tank is marked.
Name:	40 propane tank for sale (2).jpg
Alan
Old 08-12-2016, 05:41 AM   #8
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
X2 on the recertification kit!
Old 08-12-2016, 11:50 AM   #9
1977 31' Sovereign
Lynnwood , Washington
My aluminum tanks are original, manufactured in 1976. Updated valves were installed 15 years ago. Never had a problem.
BTW - My tanks were "re-certified" last year. I got my "kit" from Harbor Freight.
Tom
TomKirk is offline   Reply With Quote
Old 08-12-2016, 12:08 PM   #10
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Attachment 268863
Possibly water test the cylinder. The cylinders fall under DOT regs. To be properly recertified you can do a visual every 5 years or a pressure test and be good for 7, the tag and recert dates also have to have a RIN or VIN number associated with it. Those are the numbers of the place that did the actual testing. Whether the refill station knows what they are looking for is very questionable. My FIL took a tank that was 25 years old no OPD but looked like brand new up and had it filled at one place no problem. However that same fill place would not touch my almost new Viking FRP cylinder.... go figure.
Aaron
Old 08-12-2016, 12:21 PM   #11
1973 25' Tradewind
Redding , California
I re-certified.
My tanks were an awful brown color, original with trailer, 1973. Last certified in 1998, when they changed out the top portion. I took them down and it was 10 bucks per tank to re-certify. Sanded a little rust off, then got a couple cans of paint, and here's what I ended up with. I was surprised by the results.
ID:	268894   Click image for larger version
Leadvox is offline   Reply With Quote
Old 08-12-2016, 02:25 PM   #12
Lynn
Beaverton , Oregon
LP tank replacement
Bob.... I decided to replace my LP tanks on my 2005 Safari, I'm planning on keeping my trailer a few more years and maybe longer. After traveling around the country for awhile and realizing just how bad the roads are in the country, I decided new tanks were in order to provent any LP issues. I purchased new 30 gal tanks from Bimart when on sale and had them purged for $5.00 each at Ferrell Gas.
Lynn
aliner is offline   Reply With Quote
Old 08-12-2016, 02:58 PM   #13
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
My first reaction (brainstorming mode) would be to find a place that does tank exchange instead of refilling.
Quite common for 20 lb tanks, not so for 30 lb but I have seen a few. Not sure if they check the dates on your trade in, I've never had the date checked on a 20 lb trade in.
Greg
greghoro is offline   Reply With Quote
Old 08-12-2016, 03:16 PM   #14
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I have aluminum tanks. I get them re-certified when needed. Sometimes it has been free. The first time I took them to a company that actually pressure tested them and changed the valves. That was fairly costly. Steel ones, I might consider just buying new ones. Have not priced it
Replacing water tanks, holding tanks & battery? AussieGirl 1956 - 1959 Flying Cloud 57 10-19-2014 08:21 AM
Holding tanks gage is there a key or plugin to test the levels of the tanks. Buckshot 1999 Safari 1 08-18-2014 08:25 PM
20lb tanks vs 30lb tanks? AldeanFan LP Gas, Piping, Tanks & Regulators 5 04-05-2014 12:37 PM
'Convert' from 30# tanks to 40# tanks HeavyAssault LP Gas, Piping, Tanks & Regulators 19 11-28-2013 11:42 AM
LP Gas Tanks: Replacing 20# with 30# tanks? Pete Vermont LP Gas, Piping, Tanks & Regulators 28 01-30-2008 08:34 AM
