Old 08-12-2016, 04:41 PM   #15
2004 28' International CCD
Daphne , Alabama
I had the same problem, I decided to recertify one tank and keep the other one as a back up and only refill the one that was recertified. Works for me.
IAMGLG is offline   Reply With Quote
Old 08-12-2016, 07:19 PM   #16
2003 25' Safari
Tucson , Arizona
On my 2004 Safari I replaced both tanks after having gotten caught in Canada with 13 year old tanks. Got them on sale from Amazon for about $65.00 each delivered. Same ones Camping World sell for about $100.00 each. By the way, if going to Canada, go with full tanks. Not many places will fill any tanks. Apparently they do an exchange program. And yes the US is for 12 years but Canada if only 10 year.
Skykiva is offline   Reply With Quote
Old 08-12-2016, 08:55 PM   #17
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
I've only seen the exchange program for 20 lb tanks, like they do south of the border. There shouldn't be a problem finding propane in Canada, unless you're in a remote area. Last time I had a 20 lb BBQ tank filled at the TSC near my home it cost CDN$13.56 including tax, which is about US$10.
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 08-12-2016, 10:27 PM   #18
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
Crystal Beach Variety in Shuniah ON, just east of Thunder Bay has 30 lb exchange.
Greg
greghoro is offline   Reply With Quote
Old 08-12-2016, 11:02 PM   #19
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I am curious about how using exchange bottles would work. It seems that the chance of needing to have a bottle filled while camping some distance from your bottle provider might be problematic.
Ken
Old 08-13-2016, 05:09 AM   #20
Gainesville , Florida
You can refill an exchange tank.
Old 08-13-2016, 05:10 AM   #21
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Me? I'd just buy new ones and avoid the costs and hassle. K.I.S.S.
MelGoddard is offline   Reply With Quote
Old 08-13-2016, 06:06 AM   #22
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
The Blue Rhino and Amerigas exchange thing provides less than a full tank... its like 14.7 pounds whereas when you go to a fill company yu actually get a full tank! I would invest in aluminum bottles and have them last forever despite the inital cost!
Old 08-13-2016, 06:38 AM   #23
2012 30' Classic
Homosassa , Florida
I will have mine recertification when the time comes and replace if necessary. Not going to chance a safety issue to save a dollar.
Tater is offline   Reply With Quote
Old 08-13-2016, 08:44 AM   #24
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I had a valve go bad on an old tank (needed to be re-certified) while traveling last year. The valve knob was stuck and would not turn off. I could not find a 30# exchange. I decided to just replace the whole thing. A new 30" steel tank at Tractor Supply was ~$70. Problem was, they would not dispose of the bad tank, so I had to haul it in the back of the truck till I got home. I knew our local county dump recycles propane tanks.
How have you disposed of old bottles while on the road?
Alan
Old 08-13-2016, 09:08 AM   #25
1976 31' Sovereign
Oswego , Illinois
My propane supplier visual checks aluminum tanks if opd valves no damage or welds, nothing else need to be done for recertify. NO CHARGE to recertify if pur. gas, also stated no pressure test for aluminum tanks, only steel.
Old 08-14-2016, 08:55 AM   #26
1964 24' Tradewind
Lawrence , Kansas
I recently twisted off the handle on my valve. Took it to Hetco and they replaced the valve and recertified it. Do not remember how much it was exactly but it was surprising cheap. They had to burn off the gas and replace valve and certify the tank and did it for about $17.00. I had the second tank recertified at the same time for about $5.00. Before I took them in I sanded them, treated any surface rust, and repainted them.
ttbikes is offline   Reply With Quote
Old 08-22-2016, 11:44 PM   #27
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Update.
Hi, today I took my tanks to my local propane dealer. One was nearly empty so I had it filled while I was there. A visual inspection and leak test was performed. The cost per tank was $10.00. As you can see my tanks were not a date match from the Airstream factory.
ID:	269824   Click image for larger version
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-23-2016, 01:05 AM   #28
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
I don't know if it is province by province but here in BC recertification involves a new valve and inspection and is good for another 10 years. I just had it done for $23 Canadian as a new 20lb tank at Costco is $37.
Seemed the way to go.
George
gandttimes is offline   Reply With Quote
Replacing water tanks, holding tanks & battery? AussieGirl 1956 - 1959 Flying Cloud 57 10-19-2014 08:21 AM
Holding tanks gage is there a key or plugin to test the levels of the tanks. Buckshot 1999 Safari 1 08-18-2014 08:25 PM
20lb tanks vs 30lb tanks? AldeanFan LP Gas, Piping, Tanks & Regulators 5 04-05-2014 12:37 PM
'Convert' from 30# tanks to 40# tanks HeavyAssault LP Gas, Piping, Tanks & Regulators 19 11-28-2013 11:42 AM
LP Gas Tanks: Replacing 20# with 30# tanks? Pete Vermont LP Gas, Piping, Tanks & Regulators 28 01-30-2008 08:34 AM
