Old 03-30-2007, 07:55 PM   #1
bevman's Avatar
1958 22' Flying Cloud
Saint Helena , California
New tanks, old regulator...
I know that I have to replace the old style tanks, but I'm trying to do this in stages. Can I use the existing regulator/switch, with new supply hoses? I'm puzzled by the connection (old copper flared line). I took off the line, and then the connection at the bottom of the regulator. Inside, was a square, spring loaded deal that looked like a graphite brush in a motor. It was pressing against a needle-thing coming down out of the regulator body.
ID:	34869   Click image for larger version
bevman is offline   Reply With Quote
Old 03-30-2007, 08:58 PM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Is that a line for a gas lamp? pilot light?
I happen to have two 30# 1 year old Al tanks that I no longer need.
Michelle TAC MT-0
Sarah, Snowball
Old 03-30-2007, 09:03 PM   #3
bevman's Avatar
Nope. That line is where the supply from one of the tanks goes up into the body of the regulator. High/tank pressure before the reg. does its stuff. (Someone has fiddled with it between 1958 and the invention of Teflon tape.)
Old 03-31-2007, 12:59 AM   #4
1960 24' Tradewind
santa barbara , California
Hello bevman ,
That fitting you unscrewed needs to be reinstalled back into the regulator.
Hold the larger fitting with a wrench ,then unscrew the smaller fitting with a line wrench or flarenut wrench if you have one ,or a regular wrench ,careful not to (round) the hex .You then can install the newer rubber hoses if you like ,or you can leave those copper lines on and fit up your newer tanks to
the lines .The rubber lines do offer easy on off tank connections though .
The fitting can be changed (previousely dicussed) at the large fittings in your regulator to hook up rubber hoses .The RV store can help you out with the right ones .
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 03-31-2007, 07:16 AM   #5
bevman's Avatar
Thanks, I assumed that that fitting was necessary but what does it do?
Old 03-31-2007, 07:20 AM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It looks like the one way valve to keep LP from going from a full tank to an MT tank.
Old 03-31-2007, 07:25 AM   #7
bevman's Avatar
That would make sense, but there is a left/right dial that switches from tank to tank. Maybe it's needed to keep cross bleed from happening as you get the dial in the middle.
Thanks for solving the mystery.
There's no reason that I can't use this original-equipment regulator, is there? (I can't imagine that the laws of physics have changed much.)
Old 03-31-2007, 07:42 AM   #8
Well Preserved
1993 21' Sovereign
No reason, BTW, that is an automatic changover valve. It will start using LP from the tank that the arrow on the valve is pointing to. When that tank is MT, it will automatically switch to the other tank, and a little red flag will pop up in the sight glass, letting you know the first tank needs refilling. If it works right, you can unscrew the line to the MT tank without leaking gas, and save having to relight everything. If you put the arrow in the middle, it will defeat the purpose of the auto changover valve, if it allows LP through it at all.
Old 03-31-2007, 07:55 AM   #9
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Bevman-
Since you are going to already replace the tanks why don't you replace the whole set up. New is sometimes better than old. A new regulator for twin tanks with an auto switch over is only around $40. This way you will will have piece of mind and no problems.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 03-31-2007, 08:12 AM   #10
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
New, cheap reg or old, quality reg?
Originally Posted by rickandsandi
... A new regulator for twin tanks with an auto switch over is only around $40. This way you will will have piece of mind and no problems.
I have not heard of anyone getting long life out of the $40 regulators. The regulator in Bevman's picture appears to be a Fisher brand regulator, and Fisher is an excellent name in the business. New Fisher regulators are available, but they are pricey.
I would keep the Fisher as opposed to replacing it with a $40 reg.
Tom
Old 03-31-2007, 08:32 AM   #11
bevman's Avatar
If the Fisher ever starts misbehaving can it be repaired, or do I have to play Taps over it?
Old 03-31-2007, 08:37 AM   #12
Well Preserved
1993 21' Sovereign
I seem to remember they can be rebuilt, but that may be old memory cells acting up...
Old 03-31-2007, 09:16 AM   #13
TomW's Avatar
1967 26' Overlander
Yes, the regs can be rebuilt, and there was a fella that signed up to this forum just to let everyone know he could get Fisher rebuild kits. Do a search, and you can probably find the post.
Tom
Old 03-31-2007, 09:31 AM   #14
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
One of the first things we did was rebuild the lines around the tanks/regulator. Found a leak where someone over tightened a fitting and cracked the copper nut. We kept the old regulator. The new tank lines are so much easier to remove/replace. If you use tape on the fittings remember there is a special yellow tape for gas lines.
Pressure Regulator pjtaia LP Gas, Piping, Tanks & Regulators 4 09-24-2002 07:26 PM
where to buy new aluminum lp tanks.. JohnGalt48 LP Gas, Piping, Tanks & Regulators 3 09-14-2002 10:36 PM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Aluminum Tanks uwe 1970-79 Tradewind 2 07-17-2002 01:56 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
