Old 05-25-2006, 10:05 AM   #1
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Angry New tanks are taller
I recently bought 2 new aluminum (30#) lp tanks from VTS. They are now polished and ready to fill. I went to dry fit them first this morning and found that they are taller then the old steel tanks by 2 1/2 inches. The old tanks are 24" tall and the new ones are 26 1/2" tall. The rod is too short and will not work. The tops of the tanks are a little different also. The aluminum tanks habe a rolled top and the steel ones are not rolled. I can grind the upper clamp to fit the tanks with my Dremel, but what to do about the lenth of the rod. Can I get a longer rod that pins at the bottom or should I get a long full threaded rod and use nuts at the bottom? I do need to match the thread size at the upper clamp.
Richard
Old 05-25-2006, 10:11 AM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
You should be able to get the same size "All Thread" (threaded rod) @ Home Depot or Loes, cut to lenght. If not, maybe my '73 still has one, I can measure and see if it will fit.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 05-25-2006, 10:23 AM   #3
2002 25' Safari
Dewey , Arizona
Images: 62
I just took another look at it and the rod is 32" long. The pin is 3 1/2 inches from the bottom of the rod. Thr rod has another hole higher up which I think would be for 20# tanks. I wonder if it has a lower hole that I can not see since it is iinside of the tube on the frame? Either way, I travel with the older steel tanks tonight. One is almost full and that is plenty for a long weekend. Let me know what you find out about your 73 rod. Thanks....
Richard
Old 05-25-2006, 11:03 AM   #4
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
All Thread is the solution
Balgrn has the answer: All Thread rod. Adjust it to the height you need up top to secure the two beautiful new aluminum tanks, with the excess on the bottom, then put double nuts and washers above and below the hole thru which the All Thread goes. Cut off any excess rod from the bottom.
More weight: I bought 3' of clear plastic tubing having an inside diameter equal to the outside diameter of the All Thread, cut the plastic tubing to fit the All Thread above the frame rails, then pushed the clear tubing on the All Thread, leaving enough exposed All Thread on top for the spin on handle that helps holds clamp (and tanks) in place.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 05-25-2006, 11:16 AM   #5
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
In addition, I would use loctite and/or nylock nuts on the top and bottom.
Bill
Just my personal opinion
Old 05-25-2006, 12:29 PM   #6
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
On some, I've seen the clamp bracket at the top go through the hand hold portion of the tanks instead of the top edge. This may make up the 2-1/2" to 3" difference until you get a new all-thread rod ~
Shari
Old 05-25-2006, 12:35 PM   #7
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Machine Shop for Stainless Steel
I had a local machine shop thread a SS rod top and bottom for my replacement. My issue was the old rod was mangled and cross threaded by the PO - the Caravel had no tanks when I bought it. The cost was very little - I think $11 bucks was the total and the guy had the materials on hand. Check and you may be shocked at what they can do for you.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 05-25-2006, 01:03 PM   #8
wlj1943's Avatar
1970 18' Caravel
Mulino , Oregon
Aluminium tank solution
azflycaster,
I did the aluminium tank conversion last year. On my unit (1970 Cerritos built 18' Caravel) I punched out the rollpin that secured the lower end of the rod and found it was drilled for the taller tanks. Reinstall with a new roll pin or stainless steel hardware so the rod is taller. I reworked the regulator mount on the casting via an aluminium adaptor plate for a new regulator and installed a longer stainless steel flex to accomodiate the taller tanks. I found the fit and holding security for the tanks of the cast aluminium retainer was better through the side holes; so I just fabricated a 6061-T6 aluminium tube spacer about 2 1/2 inches long so the cast nut fit above same correctly. Use nylon washer as per the original between the nut and the spacer to prevent galling and be sure your casting wingnut has a stainless heli-coil installed also to prevent galling and seizure, not all early units had this installed from the factory. Also use anti-sieze compound on the threads periodically to keep the rust god at bay; the dissimmiliar metals really accelerate corrosion of the threads in the steel rod. All-thread is a second possibility but the smooth steel rod I think looks better; I zinc plated mine after derusting and then used the famous aluminium rustoleum rattlecan to finish it off.
All said a really great improvement!
You can email me at wlj1943@molalla.net if you want me to send you some digital photos in a few days when I get back home.
WLJ1943
wlj1943 is offline   Reply With Quote
Old 05-25-2006, 02:03 PM   #9
lewster's Avatar
Naples, FL , Hood River, OR
Lp Tank Lock
Hi All,
This is probably a good time to bring up the subject of LP tank locks. It is a little device that slides over the threaded rod and locks on to it with a key cylinder. It will not allow the large wing nut clamp to move....thus securing your cylinders.
If there is any interest in this little gizmo, I will post it in the classifieds with a photo. $10 plus shipping. Cheap insurance for your tanks!
Let me know!
Old 05-25-2006, 02:06 PM   #10
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Originally Posted by lewster
Hi All,
Let me know!
Lew,
I would like to see that.
Bill
Old 05-25-2006, 02:09 PM   #11
lewster's Avatar
I'll have to get a shot of the one that I have on my CCD. I'll try to post it tonight.
Old 05-25-2006, 03:01 PM   #12
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Hi All,
Let me know!
Yeah - post away.
Uwe
www.area63productions.com
Old 05-25-2006, 05:07 PM   #13
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I had the same issue when we changed from the steel tanks to the aluminum ones, and found that instead of clamping to the top edge, as we had with the steel tanks, we could clamp to the hole in the side of the top bracket, which was the same height as the top of the steel tanks.
Old 05-25-2006, 05:38 PM   #14
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
The 73's pieces are gone.
BEST TO GO NEW!
www.balrgn.com
where to buy new aluminum lp tanks.. JohnGalt48 LP Gas, Piping, Tanks & Regulators 3 09-14-2002 10:36 PM
LP Tanks Craig LP Gas, Piping, Tanks & Regulators 6 08-22-2002 08:43 AM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Aluminum Tanks uwe 1970-79 Tradewind 2 07-17-2002 01:56 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
